how-to: ECU-based direct boost control
#558
#559
#560
#562
quick question
I was playing w/ my rom tonight, and decided to sorta upgrade MUT tables, from an older version. I was checking to make sure the few request IDs I do know, were the same. In doing so, I noticed request ID 38, which is JDM map sensor... In my MUT table it reads 6AED. I am running the direct boost control, and the variable for boost control is 6AEC. Should this be changed to "6AEC"?
#564
Thanks!
#566
I had my first issue w/ temp. change and overboost this weekend. (In Cali) So I have been tuning the car in 70-90* + weather, and this weekend w/ all of the storms, and it being winter and all, it was ~ 60 ish, maybe less, and I over shot boost by almost 4 psi... Way too much! This is w/ "direct boost control"... I was under the impression this method would account for weather temp. change a lil better than this... Should it react this way? 4 psi is a bit much, dont ya think? I have been told that approx. ~ for every 10* drop in temp. you get 1 psi more. Is this somewhat accurate?
The only thing I have done to the rom recently is adding the knock control, ignition trims, and the periphery blobbits. I started to read up on, but dont understand the periphery blobbits... Could this have an adverse affect on anything? I know theres a lot of stuff going on there. I didnt change any of the values.
Oh and I made my BB/MWGDC tables high and low instead of tables 1, 2 and 3.
I dont think this would have any adverse affect, but I am trying to figure out why I overboosted 4 psi.
TIA
TIA
#567
TIA
TIA
to recap from the other thread, I have colder weather overshoot as well with psi based direct boost control.
upward tps correct 0'ed out ect, still spikes of almost 4psi...
#569
it does not over shoot unless its cold or in offset gears. do you think it is a hardware issue? temp has to be -20 from normal for it to do this.
nonschlont has gm in his sig.. Im thinking its rom related, but Im a driver not a tuner so need the smart guys here to let us know how to best fix it
#570
no, i have been lazy and still use my aem bcs.. I need to go order gm 3 port soon.
