how-to: ECU-based direct boost control
Old May 16, 2009 | 11:33 AM
  #661
Evo8Emperor's Avatar
Yah its in my evo7base xml. I was curious should the endian be big or little seeing im using 1.4 ?
Old May 16, 2009 | 11:54 AM
  #662
nano's Avatar
anything above 1.31 should be big
Old May 17, 2009 | 05:45 AM
  #663
Everything is good now it was just that one endian I must have forgot as always something. I was curious if I was getting this right though.
Seeing the Max is 24.6 and I want 30 psi. Im at sea level here in RI some 14.6-7 I would have a adder of 20.1.
30+14.7=44.7 44.7-24.6=20.1
Im running meth so I want to 29-30psi spike and see what it will hold after that. Normally I would always end up with a high 22psi sometimes 23.
Before this my evc was limiting to 25 psi until I tightened my wastegate 2 turns and I got 27-28 psi. So all should be good. Well find out though. lol.
Old May 25, 2009 | 07:36 PM
  #664
shadow1's Avatar
FYI: for those that use Logworks, I translated the Evoscan formulas to Logworks. I haven't tested it yet (waiting for my Perrin EBCS):
<datachannel id="#8A" name="Boost Error" selected="0" units="psi" min="-5" max="5" expr="0.0241*x-3.087" type="0"/>
<datachannel id="#8B" name="WGDC Correction" selected="0" units="WGDC%" min="-50" max="50" expr="0.5*x-64" type="0"/>
Old May 30, 2009 | 07:34 AM
  #665
shadow1's Avatar
Hopefully not a dumb question, but does anyone know why there are 3 WGDC tables and 3 baseline boost/BDEL tables? Also should all 3 tables be set to the same values? Ditto the two WGDC Correction Interval tables - should I set both to the same value and why are there 2 tables?
Old May 30, 2009 | 07:59 AM
  #666
musca999's Avatar
Originally Posted by mrfred
Instructions for EvoScan
Add the following entry to your EvoScan "Data.xml" file:
-----snip----
This looks exactly like what WORKS does. They provide the modified restrictor pill in the boost tubing already.
Old May 30, 2009 | 08:39 AM
  #667
fostytou's Avatar
EvoM Community Team
https://www.evolutionm.net/forums/ec...t-control.html
You can set them for gear based control or just make them the same.
Old May 30, 2009 | 10:47 AM
  #668
shadow1's Avatar
Thank you!
Old May 31, 2009 | 08:26 AM
  #669
I just got back from a few pulls with my gm solenoid and I have my boost error table set to 0 and my max wastegate duty cycle at 100% all the way and it actually matches my boost tables.
Is this bad that my wastegate duty is at a straight 100% right to redline ?
Old May 31, 2009 | 12:52 PM
  #670
R/TErnie's Avatar
Any suggestions on how to get more boost out of the system?
AEM EBC Solenoid
.050" restrictor
FP High pressure actuator
FP red turbo
hitting 30psi at 5500 tapering to 26/27 by 8k
Old May 31, 2009 | 02:12 PM
  #671
mrfred's Avatar
AEM EBC Solenoid
.050" restrictor
FP red turbo
With the 3-port solenoids, 100% WGDC means that the WGA is venting to atmosphere which is the best that can be done in terms of the least amount pressure on the WGA diaphram.
The only thing left is to fiddle with the WGA spring or preload (or open up the exhaust further to reduce exit pressure on the turbine).
Old May 31, 2009 | 02:28 PM
  #672
GST Motorsports's Avatar
AEM EBC Solenoid
.050" restrictor
FP red turbo
GM 3 port
Straight lines, no pills
Forge red spring actuator
FPred
3rd gear
Still had more duty cycle, had it at around 33psi at one point but didn't need the power at that time.
Old May 31, 2009 | 02:35 PM
  #673
The only thing they change in the tables are BW, BDEL, Offset and Error correction.
They do not change anything else.
Old May 31, 2009 | 06:48 PM
  #674
fireroasted's Avatar
Was wondering if some can help identify why I can't seem to follow the steps for Tuning the boost. I have followed the instructions, but am still over boosting, and going through the steps and removing the BEC, or setting them to zero can be dangerous with whatever I have going on.
The reason I am doing this is because I was getting boost spike up to 27 psi, and I am all stock TBE 9MR. My target would be 25 then taper. I have the JDMMAP, a GuppeS BS, and IC pipes.
Can anyone help me identify what I am setting incorrectly based on the image below, or let me know what you need to see.
I have also attached a zipped csv file of the log. Not sure if I hit the boost cutoff or what that should sound or feel like, but whatever it was at WOT, it wasn't good I suspect.
Thanks for any help.
File Type: zip
Old May 31, 2009 | 06:57 PM
  #675
shadow1's Avatar
You left a "[" off your IMG
Quick Reply: how-to: ECU-based direct boost control
