2-byte RPM HOW-TO
Old Oct 3, 2007 | 08:46 AM
  #31
roger smith's Avatar
fryedchikin, here is an example for requestIDs 2 and 3
Code:
<Request LogReference="RequestID02" RequestID="02" Eval="x" Unit="INT" Logged="y" Response="2" />
<Request LogReference="RequestID03" RequestID="03" Eval="x" Unit="INT" Logged="y" Response="2" />
<Request LogReference="RPM-2byte" RequestID="FF" Eval="((256*RequestID02)+RequestID03)*1000/256" Unit="2byteRPM" Logged="y" Response="2" />
Old Oct 3, 2007 | 05:37 PM
  #32
Jack_of_Trades's Avatar
Well, I found a small glitch than MIGHT cause a headache to anyone trying to get their evoscan to log the right values. As Dave mentioned already, you might need to change the evalution formula to 1000x/256. This doesn't work and the values come out screwy with evoscan unless its written as 1000*x/256. Without the asterisk, it doesn't complete the formula correctly. I also changed the scaling to mimic the standard RPM values on the graphs so the 2 byte rpm doesn't go wayyy off the charts as the rpm goes up.
Here's the code I am currently using and it works great:
Code:
<DataListItem DataLog="N" Color="" Display="RPM MUT 2Byte Mod" LogReference="RPMMUT2Byte" RequestID="02" RequestID2="03" Eval="1000*x/256" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="8" ChartMin="0" ChartMax="80" ScalingFactor="0.01" Notes=""/>
Old Oct 3, 2007 | 05:44 PM
  #33
laakness's Avatar
Code:
<DataListItem DataLog="N" Color="" Display="RPM MUT 2Byte Mod" LogReference="RPMMUT2Byte" RequestID="02" RequestID2="03" Eval="31.25*x" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="8" ChartMin="0" ChartMax="80" ScalingFactor="0.01" Notes=""/>
Jack, you beat me to it I was just coming on to post about the * thing. Nice work getting this all in one thread.
Old Oct 3, 2007 | 07:08 PM
  #34
trinydex's Avatar
how does the * fix it?
Old Oct 3, 2007 | 07:14 PM
  #35
It makes the formula "correct". Otherwise the program gets confused and calculates the wrong values. The asterisk is the multiply symbol for whomever doesn't know that (not saying you didn't). Don't know why evoscan won't work without it, it just doesn't
Old Oct 3, 2007 | 07:42 PM
  #36
fryedchikin's Avatar
Code:
Thanks a bunch, it works like a charm
Old Oct 4, 2007 | 12:04 PM
  #37
Jeff_Jeske's Avatar
WOW I have a headache from reading about all this two byte crap!!!
Here is what I have in my type 15 XML (entered values are listed in table name)
<table name="2-byte load high 27458" address="3EE86" category="MUT" type="1D" level="1" scaling="uint16" />
<table name="2-byte load low 27459" address="3EE8A" category="MUT" type="1D" level="1" scaling="uint16" />
<table name="2-byte Airflow High 27550" category="MUT" address="3EE8E" type="1D" level="1" scaling="uint16"/>
<table name="2-byte Airflow Low 27551" category="MUT" address="3EE92" type="1D" level="1" scaling="uint16"/>
<table name="2-byte RPM high 0x6B1E" address="3EE96" category="MUT" type="1D" level="1" scaling="Hex16" />
<table name="2-byte RPM low 0x6B1F" address="3EE9A" category="MUT" type="1D" level="1" scaling="Hex16" />
I have request:
00 and 01 for 2B-Load
02 and 03 for 2B-Airflow
04 and 05 for 2B-RPM
I've edited my EVOScan as well:
<DataListItem DataLog="N" Color="" Display="2-Byte Load Mod 00/01" LogReference="LoadMUT2Byte" RequestID="00" RequestID2="01" Eval="0.3125x" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="500" ChartMin="0" ChartMax="500" ScalingFactor="1" Notes=""/>
<DataListItem DataLog="Y" Color="" Display="2-Byte AirFlow Mod 02/03" LogReference="AirFlow2Byte" RequestID="02" RequestID2="03" Eval="6.29x/64" Unit="Hz" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="3000" ChartMin="0" ChartMax="3000" ScalingFactor="1" Notes=""/>
<DataListItem DataLog="N" Color="" Display="2Byte RPM Mod 04/05" LogReference="RPMMUT2Byte" RequestID="04" RequestID2="05" Eval="1000*x/256" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="8000" ChartMin="0" ChartMax="8000" ScalingFactor="0.1" Notes=""/>
What else do I need to add to my EVOScan XML for display purposes? (formulas???)
Old Oct 4, 2007 | 12:34 PM
  #38
merkzu's Avatar
Code:
That worked great, thanks!
Old Oct 4, 2007 | 01:05 PM
  #39
Evo_Jay's Avatar
Code:
So what one is it?? In you post you talk about 1000*x/256, but then the code your currently using has it as 31.25*x??
Old Oct 4, 2007 | 01:15 PM
  #40
merkzu's Avatar
It's 1000*x/256 and the scaling is .01
Old Oct 4, 2007 | 04:17 PM
  #41
OOPS! lol, sorry. I cut and pasted parts from my desktop instead of my laptop. Must have forgot to edit that before posting it. You should use the 1000*x/256.
Code:
Old Nov 30, 2007 | 04:15 PM
  #42
broddey's Avatar
Hey where do you guys post the <DataListItem Datalog. . . . script?
I modified my xml files for both ecuflash and evoscan 2.0 for the 2 byte RPM and Load mods, but when I try and log with them, I get erroneous values.
What else needs to be modified?
Old Nov 30, 2007 | 05:03 PM
  #43
You need to change those hex values in ecuflash and flash your ecu. If you just change the xml files your evoscan will be reading info from the wrong location in the ECU.
Old Dec 4, 2007 | 08:32 PM
  #44
broddey's Avatar
I have changed the xml with the <table name = . . . values in both evoscan and ecuflash for my respective rom (13)
I also input the values in Ecuflash for 2byte rpm and load.
Where is the <DataListItem code need to be written?
My problem is that I am still getting rediculous values in the readings.
Old Dec 5, 2007 | 02:58 PM
  #45
broddey's Avatar
My Load and RPM look like stalagtites in a cavern.
Quick Reply: 2-byte RPM HOW-TO
