PATCH: NLTS + Valet + KnockCEL
#199
I gotta say, this is by far the most fun mod you can do to these cars!(besides adding an additional 400whp lol).
I fully tested the 9470014 NLTS and the only issue I had was when going from 1st to 2nd once, it literally fell flat on its face during the shift. Its as someone else mentioned previously....its like the NLTS stayed activated even though I shifted.
The valet mod works great but I don't know about the KNOCK CEL since I got 0 counts on my runs (ain't complaining! haha). I will paypal you some cash later tonight Teph, freaking sweet job man.
#200
Ok just tried to get this to work. I copied everything over to the patched rom provided for the 96940011 and the car wouldn't even start. It just cranked. I double, triple and quadruple checked everything and it should be right. I flashed back to the non patched rom and the car starts right up.
Now, last night when I switched everything over there was only two xml for the different versions of evoflash. I checked today and there was 3 xml I thought that might have been the problem, so then I recopied the new xml for evoscan 1.30, which is what I'm using. Was the patched 96940011 rom changed aswell from last night to today?
#201
damn I am lost, I went away from this site about a year ago, come back and now all this new cool stuff is happening. I tried to modify my ROM but its not working. I can't seem to figure it out, would someone mind explaining this to me?
I've opened the zip file for 96940011 and there are 3 xml files and one bin file. what am I supposed to do with each? I attempted to copy the lines from the XML file for ecuflach v1.3 to my evo7base rom but that didn't work.. I'm lost.
#202
yikes lots of posts :|
There is a bug with the knockcel at the moment guys - nothing too bad, it just doesn't keep flashing after the event! i will fix this asap
Non-starters please ensure you have removed any old XML (from all xml files) and then reuse the new ROM... the old XML overwrites the new code if you use them to edit on the new ROM
Cheers
D.
Cheers
D.
#205
The .bin file is the actual modded ROM. You will have to open this rom in ECUflash after you've modded your XML file and then open the rom you have in your ecu now. You then have to copy EVERYTHING you've changed in your current rom into the modded one and reflash with the modded one now set up for your car.
#206
Cheers
D.
Cheers
D.
#209
Certain versions of ecuflash use little or big. And I noticed this, what will happen is the cel on time will automatically reset itself to an insane number each time you open or close it. And your changes will not stay at first.
I saw this when I reloaded the rom and switched the endian and it wasn't a problem.
#210
Cheers
D.
Cheers
D.
so i actually know if I am still knocking rather than wondering if its the timer so i'm cool with it brotha again man you rock if you were local i would take you out for drinks/fun on me
