PATCH: NLTS + Valet + KnockCEL
#466
hey scott, doublecheck the injector info, i did the same thing when i was copying everything over the first time and forgot that i had upgraded injectors and i hit fuel cut pretty quick like.
#468
I'm thinking maybe the top clutch switch never gets a chance to contact the pedal? I've never physically looked at the switch, so I don't know if it moves with pedal adjustment or not. Just a thought, since I have an 05 working fine (although different ROM maybe) and a few people have tried the ROM posted here successfully.
Eric
#470
This might sound dumb but i go to past the new code into the rom .xml file and i can past it in note pad but it gives me an error when i go to save that it can not save that information does someone have a link for a step by step how to.
Thanks,
Sorry for the noob question.
Thanks,
#472
Should i just paste the code at the bottom of the page before the rom statement?
#473
thats what i did...
Vista works great, but some of the added data safety features can be a pain. You can turn them off though if you dont want them. Copying to your desktop first will work though
#474
Ok i got new tables or data to put in do i need to edit any of these crazy number or just flash
I saw that people found 1500 rpm to work well so i switched that but what about
Enable Rev Limit Switching is has a value of 65535
Flash CEL on Knock? same
Enable NLTS? same
CEL on Knock Flash Time 642500 is this the number for the location to tell the dash light to flash?
I really don't know what these numbers mean if they are a location on the ecu that checks for ting or what i can see they are the X Value and some type of units.
Valet Rev limit i put to 3054
What should i put in for Valet Rev limit Time to Activate
Nlts TPS threshold i put to 20%
NLTS Speed Threshold i put a 20km/h
Enable NLTS? same
#475
Thanks,
Thanks,
#476
I've noticed an oddity: once NLTS has engaged once, the stationary rev limit appears to be gone completely (don't ask how I found that out). So, you get one launch per car start.
This is on 96940011 on an '05 MR, FYI. TTP, I'm not seeing the same issue you are; accidently brushing the clutch right after a WOT shift seems to nosedive as it should, so it's definitely keying off the upper clutch switch.
#479
Enable NLTS? same
Enable NLTS? same
-Paul
#480
Did you use the ROM he provided or are you using your original ROM? The fact that you're seeing 65535 in the enable fields indicates you're probably using your original ROM which does not have the patch. You have to copy all of your tuning changes to the ROM he provided and then flash that ROM to your ECU.
-Paul
-Paul
I really feel way slow doing this.
never mind i opened the file and closed it again and then it worked who knew.
