PATCH: NLTS + Valet + KnockCEL
#680
I wanted to add a led to flash with the CEL because I currently have the dual gauge pod on the steering column so I can't see the CEL. I was reading your other thread of when the CEL on with Knock and someone said that the led has to have 12v and be grounded to pin 36 on the ECU. Is this correct? I wanted to make sure before I went out and installed it. Thanks
#688
I use my valet as a security system (set to 300rpm so it wont start ever!) and activate it everytime I get out of the car. Is there any way to have it be active at 300rpm all the time unless I disable it when I get in the car? That way I'd never have to "remember" to activate it when I get out? I have no idea if you can manipulate the code to have it set to a default setting all the time unless deactivated.
Just throwing ideas out there.
#689
#690
This sould be very efficient protection
