PATCH: NLTS + Valet + KnockCEL
Old Nov 13, 2007, 05:34 AM
  #826
logic's Avatar
Originally Posted by dawnduran
explain me, what is NLTS?!
I read many different thinks about it in this thread.
NLTS is a acronym for "No Lift To Shift". Basically, it allows you to shift without taking your foot off the gas, by dynamically changing the rev limit to an offset of the RPM you shifted at. The benefits are that you remain in boost during the shift, you can shift at a much faster rate, and (when set up correctly) can ease the stress of shifting on the drivetrain somewhat.
Does that explain it? I believe a video was posted at some point in this forum that gave a visual idea of what this is all about, if the descriptions aren't coming across well.
Edit: Mojo Rising beat me to it.
Old Nov 13, 2007, 06:28 AM
  #827
dawnduran's Avatar
Yes, thanks. Last question: Where is the video you spoke about it?
Old Nov 13, 2007, 06:51 AM
  #828
logic's Avatar
Here you go.
Old Nov 14, 2007, 12:52 AM
  #829
Rushin's Avatar
Is it possible to get 2 byte load with this modified rom? I noticed it hasn't been mentioned yet. Is there a really simple fix that everyone did or no one cares to log 2 byte load?
Old Nov 14, 2007, 02:17 AM
  #830
evo828's Avatar
The fix is relativelly easy - you just need to state you ROM ID and maybe someone will tell you the address in ROM that you need to change: you need two addresses and two numbers that you put into them. Thats it.
Old Nov 14, 2007, 07:20 PM
  #831
Rushin's Avatar
Thanks.. Is it also that simple for an evo 8?. My rom id is 94170008. Is there a thread that has some info on this? I couldn't find much
Old Nov 14, 2007, 07:24 PM
  #832
Rushin's Avatar
nm.. found it!
https://www.evolutionm.net/forums/sh...d.php?t=272246
Old Nov 14, 2007, 09:05 PM
  #833
High_PSI's Avatar
How do I know which Rom to use? There are so many, I want to make sure I use the proper one.
Old Nov 15, 2007, 12:58 AM
  #834
evo828's Avatar
You should use the ROM with the same ID as you have when you download your ROM for your ECU into ECUFLASH. If you haven't done this yet - I suggest you to step back, try the basic stuff (reading ROM, understand a little bit what is there) and then try to play with these patches.
Otherwise - there is a big chance that you screw up something.
Link for some ECUFLASH tutorial if needed: https://www.evolutionm.net/forums/sh...d.php?t=201146
Old Nov 15, 2007, 05:50 AM
  #835
bigric09's Avatar
ive got a question.... is there any problems with flashing a car with a different rom ? for instance, my rom is the 88590015, a guy i tuned the other day was a 88590014.... i flashed him with my base flash which is built from my rom, (the 0015). His car ran fine afterwards, made some great power on the dyno and didnt appear to have any problems.... The guy called me the following day and could barely talk after the night and day difference the tune made. Just want to know if anyone has experienced any adverse effects from doing this ? Speculation isnt going to help here though.... thanks guys
Old Nov 15, 2007, 10:17 AM
  #836
honki24's Avatar
You can cross over on some ROM IDs sometimes. I have no idea what limits one from the other, but you'll know if you've crossed that line because something won't work properly or ecuflash values will look all screwy.
Old Nov 15, 2007, 11:49 AM
  #837
bigric09's Avatar
id think that as long as it was a IX to IX or VIII to VIII it wouldnt matter.... i think i have done this on more then one occasion now. I also have a few baseflashes from some vendors and they dont change maps, they change immobilizer codes and just flash..... so hopefully there arent any issues. Good thing i save base maps lol
Old Nov 15, 2007, 11:50 AM
  #838
High_PSI's Avatar
OK I got the rom Patchs, so what are proper settings?
Old Nov 16, 2007, 01:38 AM
  #839
BarryC's Avatar
I have flashed 2 ecu's one was 96530006 and the other was 96420008 with the earlier 93660005 both cars ran perfect no issues and are still running perfect now for 3 months,
Old Nov 16, 2007, 01:58 AM
  #840
evo828's Avatar
I am curious - I have 96530006 - why have you choosen to put 93660005 there - any particular reason? Have you got the 2byte load working on 9366.....?
Quick Reply: PATCH: NLTS + Valet + KnockCEL
