PATCH: NLTS + Valet + KnockCEL
Old Nov 20, 2007 | 04:26 PM
  #856
DESERTEAGLE50's Avatar
can you run meth with nlts?
Old Nov 20, 2007 | 04:35 PM
  #857
C6C6CH3vo's Avatar
That is a good question, I havent tried NLTS yet but I'm sure someone else has with water-methanol. I think Dudical runs it.
Old Nov 20, 2007 | 04:45 PM
  #858
bigric09's Avatar
yep... it works fine
Old Nov 20, 2007 | 06:10 PM
  #859
High_PSI's Avatar
I have FINALLY gotten all these patches to work. Now I have no idea what my settings should be? How do I set the NLTS to? All of the settings in these patches I am trying to set.
Old Nov 20, 2007 | 08:25 PM
  #860
bigric09's Avatar
its all up to you... you can leave most of them at the default settings... i think my rpm's are set to 250 for the track.
Old Nov 20, 2007 | 10:02 PM
  #861
High_PSI's Avatar
250 RPMS? For the NLTS? I am not sure of the settings, like I figured I should make it fall to what, 5 grand for the six speed? What each box is? What miliseconds per count of knock.
That kinda stuff, I just need a tutorial on the actual settings and how I can get them to work.
Old Nov 20, 2007 | 11:25 PM
  #862
kayman's Avatar
check the first post it explains it a bit ... but basically the NTLS has a few settings
- NTLS TPS Threshold (Sets the threshold for the throttle position (in %) i.e if you want it to activate when you have the throttle pushed over half way you would set it to 50% most people find 90% and above doesnt interfear with normal driving (I have mine set to 97% so NTLS only works when on full gas)
- NTLS Speed Threshold (Sets the minimum speed you have to be going before NTLS will be enabled, most including me have it set to about 30kmph so you are able to take off and launch normally)
- NTLS RPM Drop (determins how much the revs will drop by when the clutch is depressed i.e if this was set to 1000 you are at 6000 revs and the above 2 conditions are met and you push the clutch in it will drop to 5000 and hold it there until you let the clutch back out), I have mine set to 1500 on the 6 spd.
The defaults on the knock sum work well and the CEL light will flash when a knock count of 4 or more is detected and you have 150% load.
Valet mode is described quite well in the first page, hope that helps ya!
Old Nov 21, 2007 | 03:49 AM
  #863
BarryC's Avatar
Originally Posted by awadkhan
so wats the update on the 93660005 tephra??.. ne luck...!!
any update on 93660005 Dave??
Old Nov 21, 2007 | 04:46 PM
  #864
tephra's Avatar
no not yet - i will try and look at it asap - work is crazy atm
Old Nov 28, 2007 | 01:09 PM
  #865
esevo's Avatar
I have tried 88590014 on my vista laptop a recieved a "unkown rom image" I then try loading on my XP personal computer same thing??? I have tried loading 015 in my car and it does not start? And yes I changed the immobilizer. Is it Vista related? Any help will be great!!!
Old Nov 28, 2007 | 02:30 PM
  #866
Evo_Jay's Avatar
I dont know, But i do know vista sucks
Old Nov 28, 2007 | 04:00 PM
  #867
tephra's Avatar
you got the 88590014 XML in your ecuflash dir?
Old Nov 28, 2007 | 04:05 PM
  #868
kayman's Avatar
if you tried it on xp and got the same error then it kind of rules out being a vista problem yeah? Try download it again it could have got corrupted during download and make sure you have the appropriate xml file as Tephra suggests above.
Old Nov 28, 2007 | 04:31 PM
  #869
esevo's Avatar
Tephra- yes I do have it there...???
Kayman- I was referring to the 015 rom that does work and why it does not start. (vista is my laptop, XP is desktop) :-) So something is wrong with 014 and I cant get 015 to work.
Old Nov 28, 2007 | 04:33 PM
  #870
tephra's Avatar
screenie of the error message?
Quick Reply: PATCH: NLTS + Valet + KnockCEL
