PATCH: NLTS + Valet + KnockCEL
Old Nov 28, 2007 | 04:38 PM
  #871
kayman's Avatar
Originally Posted by esevo
Kayman- I was referring to the 015 rom that does work and why it does not start. (vista is my laptop, XP is desktop) :-) So something is wrong with 014 and I cant get 015 to work.
from what youve said it seems like 014 doesnt work on xp or vista and 015 works on which one xp or vista or both?
seeing as 014 doesnt work on vista or xp it seems like there is something wrong with that ROM and doesnt relate to your operating system unless 015 works on XP and not on Vista then it gets a bit strange.
What version of ECUFlash are you using? and what is your actual ECU 014 or 015?
Old Nov 28, 2007 | 04:49 PM
  #872
esevo's Avatar
015 works on vista until i try flashing it over my 14 rom or my friends 15 rom then it wont start on either... both having immobilizers changed & showing correctly, so it is my guess its a vista problem.
14 seems like a rom problem. BTW Im using ecuflash 1.30
Old Nov 28, 2007 | 04:53 PM
  #873
esevo's Avatar
let me just say using my own 014 rom I can see the tephra mod options in ecuflash, I know I cant use them with out the new rom. So im guessing Im editing the XML correctly.
Old Nov 28, 2007 | 04:54 PM
  #874
kayman's Avatar
maye try using the latest ECUFlash and try download the existing ROM on your ECU and then write the same ROM back without changing anything to see if it works. I'm pretty sure ECUFlash works fine with Vista but maybe you need the latest ver.
Edit: if u can see the mod but the numbers are skewed with your ROM its most likely that you have done the editing correctly, Tephra can confirm this
Old Nov 28, 2007 | 05:06 PM
  #875
esevo's Avatar
I have thought of that.. however going threw and changing the endian="little" needing to change to endian="big" confuses me... any faster way?
Old Nov 28, 2007 | 05:18 PM
  #876
kayman's Avatar
i just did a find and replace in notepad or you can look for a newer xml definition for your file
do a replace for endian="little" to endian="change2big"
then
do a replace for endian="big" to endian="little"
then
do a replace for endian="change2big" to endian="big"
otherwise your going to have to manually go thru and do em.
Old Nov 28, 2007 | 05:27 PM
  #877
esevo's Avatar
Good call Ill try that. thanks!!
Also big thanks to Dave for his help!!
Old Nov 28, 2007 | 09:25 PM
  #878
High_PSI's Avatar
what are some good settings to use? I have a IX MR?
I only want the NLS to work at WOT
I want a 5 Second Valet Switch
I want to shift at 7500 and have the RPMS drop to the perfect gears as I shift.
Not sure on the settings, help?
Old Nov 29, 2007 | 03:21 PM
  #879
chaz517's Avatar
set tps to 95% have rpm drop to 1000 and i dunno about milliseconds ms
Old Nov 30, 2007 | 11:20 AM
  #880
savior1974's Avatar
Ive tried to use this patch a few times... but it never seems to work out for me in the end. I dont understand why though.
The last time I tried to use it, The NLTS wouldn't work in first gear... I left all the setting the same as when I input it. And I revved first gear all the way to red line... I'd mash the clutch....and its bounce of my 7800 rev limiter anyway.... Can someone help me out with this? Track days tomarrow and I'm hoping to have this on and working by then.
Old Dec 2, 2007 | 03:00 PM
  #881
kayman's Avatar
NTLS has a speed threshold which by default is set to 30km/hr which means you need to be above that speed to trigger it.
have a read of the first post it has a method / settings to test it.
Old Dec 2, 2007 | 06:39 PM
  #882
High_PSI's Avatar
I still need help setting some settings. if someone could help me out. Thanks. I have the patch to work, just need settings for a 6 Speed.
Old Dec 2, 2007 | 06:48 PM
  #883
High_PSI's Avatar
Also if one does NOT want to flash NLTS but like Valet and CEL Knock, how do we remove the others if not all while flashing?
Old Dec 2, 2007 | 07:17 PM
  #884
Ryu123's Avatar
You can't choose to not flash NLTS. You can however disable it under the Tephra Mod Options and setting the Enable NLTS to 0 which disables it.
Old Dec 2, 2007 | 07:26 PM
  #885
High_PSI's Avatar
OK so under all three of those mods, if I set them all to 0, none will work?
Also what do I set the Knock count too? I just need help with the settings.
Quick Reply: PATCH: NLTS + Valet + KnockCEL
