PATCH: NLTS + Valet + KnockCEL
#961
ok, so then 100 means MAP and then anything above that is turbo (boosting)
anything before 100 mean vaccum NA / spool ?
if so then the higher the gear I am in the higher the load cells I will hit because of the speed and I am traveling at and thus more air enters?
what happens in a dyno then?
The Evo air intake doesn't have much of a ram air effect, so speed wouldn't play a role in that way. Higher gears do tend to produce higher loads at WOT though just because the turbo can build more boost.
#962
help would be much appreciated -- i cant drive like this....
stock IX maps and everything -- only thing added was this patch.
only started happening right after i installed this patch. basically ill be driving, 3-4k rpm, then say i want to hit boost and accelerate. it will start too, and then the car will jolt -- almost like I slammed on the brake.
also, slamming through gears (I was trying to figure out how/when I got this problem) going through the gears very quickly, shifting in the high 6k range, everytime i depress the clutch my car would jolt the same way, like someone was pressing the brake. and then 2-3 seconds later i would have control of the accelerator again.
did i do something wrong?
#964
all i did was apply the patch to my rom (88590015) and i should have tested it but didnt. . . .
currently settings sit at:
NLTS RPM DROP 1500 units
NLTS TPS Threshold 70%
NLTS Speed Threshold 30km/h
i do appreciate the quick response -- makes want to scrounge for some money even more now to donate.
#966
thanks again ill repost with an update!
#971
Silly question:
Let's say I set the time for the valet mode to 2 seconds then start the car and floor it for 2 seconds. The valet mode won't kick on while the car is running will it?
