EcuFlash 1.33
EcuFlash 1.33
http://www.openecu.org/index.php?title=EcuFlash
I guess they just release this verison today, wondering if any has upgraded to it yet.
# 2007-10-01: Version 1.33 released
* Subaru metatdata updated to version 0.79b
* removed test mode detection altogether as it causes problems on many ECUs
* fix to HC16 kernel to allow bootloader communications to complete before starting kernel
* fix bug causing extra data to be sent when loading some kernels
* improve KWP2000 resynchronization
Doesnt seem to be anything worth changing over to yet.
It appears to be nearly the same as 1.32 and works just fine with 1.31-or-later xml.
If you're seeing odd values in cells or on axis, this is probably due to the "endian" change that was implemented in v1.31. Just replace all the endian references from "little" to "big" in v1.31 and later.
