LC-1 and ECUFlash
LC-1 and ECUFlash
Ok, I combed through a bunch of old threads (and yes I used the search button) and I couldn't find any instructions for beginners like myself to do this. I have managed to do the "6-byte mod" along with changing XML definitions with notepad. Now I want to hook up my LC-1 with ECUflash so I can log AFR. I have an LC-1 from my XEDE SMART system.
Now I need to know what to do and how to do it
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
Maybe there's an old thread I missed somewhere with instructions?
first update the LC-1 to 1.10 beta firmware... this will save a stack of hassles.
then ensure that your AFR's seem correct by using logworks
then in evoscan just choose LC1 from the wideband menu and tick WideBand in the list and then go for it![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
LC1's are a little tricky sometimes![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
ps maybe make your mods list a slightly smaller font :P haha
I use Logworks and scaled the output cells to match the ECUflash cells. You can use Logworks to log anything you want and plot it in the same format as your ECUflash load cells. This seems to be the easiest way for me.
