Evoscan gauge Templates
there is only one file as this is basically one gauge with a load of small child gauges inside, one file is the template and the other is a layout file with the gauges already assigned to there associated values,
just fixed the problem now works for all versions
Zip all the files in your gauges folder and post, that will do the trick.
works fine for me
try swapping these around put the templat file in layout and layout in template I might of labeled them wrong,
let me know, BTW these only seem to work in version .99 dunno why as its the same gauge programme used in all versions of evoscan, will have to look into it.
works fine for me
Great Job
Any other templates in the works?
I am running a 7" screen with a dedicated computer on my dash, and I wanted to integrate all the gauges into one screen (hate the ricer-wanna b look), similar to a garmen g-1000 setup on aircraft (for all you pilots out there)?
Namely, afr, knock count, egt, octane, ignition, water temp, etc, because I really don't need another tach or speedo, just engine vitals.
Ideally, if I could program, I would make afr the largest indicator, and then slightly smaller digital redouts with little color indicated bars underneath to warn of over temp/range.
Post your paypal and I would be happy to make a donation!
