ECUFlash Tune Milage and Mods
Old Apr 3, 2008, 11:28 PM
  #121
JohnBradley's Avatar
92 other than Cenex was selling E20 enhanced "94 octane" for awhile. The only reason I know it was that much was any car that ran it instantly went 0.5 AFR leaner. The Shell 92 here is most likely the same thing as 93 though judging from what I have done on pumpgas with it.
Old Apr 3, 2008, 11:30 PM
  #122
Wicked E's Avatar
So at 91 octane at this elevation (6K), should I run .2 points richer than your cruise boxes?
Old Apr 3, 2008, 11:45 PM
  #123
If it doesnt have high levels of ethanol in it, I would only richen it a tad because of the altitude...or wait...no? Less oxygen means less fuel so I would leave it where it is. Do you happen to have a WB? I am not sure of the correct answer to that question since I have lived my whole life at or near sea level.
Old Apr 3, 2008, 11:58 PM
  #124
Wicked E's Avatar
wideband of course...
10% ethanol
This is just for my 91 map. I will then be using E85 while in state...
Cheers-
E
Old Apr 4, 2008, 05:54 AM
  #125
nothere's Avatar
as you go up you need less octane.
Old May 30, 2008, 04:48 PM
  #126
mrfred's Avatar
Bump for a good thread. Now that I have a working WB, I gotta do this.
Old May 30, 2008, 08:01 PM
  #127
tephra's Avatar
I've been running this mod for a while now, and i notice after a long hwy drive (like 10 mins) I get an odd "rotten egg" smell when I pull up at some lights...
any ideas?
Old May 30, 2008, 08:27 PM
  #128
SWOLN's Avatar
If you have the cat, its that, but I'm not sure why it does it.
Old May 30, 2008, 08:32 PM
  #129
RazorLab's Avatar
Received 1,056 Likes on 764 Posts
any ideas?
Your cat. How lean are you running the car at cruise?
Old May 30, 2008, 08:44 PM
  #130
tephra's Avatar
15.5 afr
i guess its the extra NO2 right?
Old May 30, 2008, 08:49 PM
  #131
mrfred's Avatar
Running that lean is tough on the cat. It causes it to get really hot.
Old May 31, 2008, 02:53 PM
  #132
PlanoEvo's Avatar
You can kiss your cat goodbye You should only use this mod if you have no cat!
Old May 31, 2008, 03:09 PM
  #133
dan l's Avatar
Many OEM cars have ran lean burn with cats. Honda started lean burning with the civic CVCC but the first one with a cat I can think of is the VX model in 92. Later in the 90's they had the HX model. Now cars like the insight are lean burn as well with cats.
What does clog cats is running overly rich (boosting a lot on the stock fuel maps), leaded fuels, sulphur in fuel, etc.....
Old May 31, 2008, 04:25 PM
  #134
RazorLab's Avatar
It would be interesting to see if those cars run metal substrate or traditional ceramic cats.
Old May 31, 2008, 08:25 PM
  #135
tephra's Avatar
well I asked the question "will this kill my cat" and everyone was like - "nah its ok"
Quick Reply: ECUFlash Tune Milage and Mods
