Evoscan error again...
I have finally got a USB-Serial adapter and when I hook everything up and start EVOscan, it says the following:
Error: Unable to open COM1
Access is denied
I have the innovate lc-1 and its selected as well and the wideband box is checked off as well on evoscan
The wideband with the serial adapter is assigned to COM1 and the Tactrix cable is COM6...
Why am I getting this error?
Thanks
Access is denied
Thanks
it still didnt work, I selected the right one and still nothing. Is it possible my adapter is wack? It comes up on device manager and everything, still doesn't work on evoscan
It didn't come with a install CD...I may just return it, I bought it from Fry's...
http://shop3.outpost.com/product/416...H:MAIN_RSLT_PG
You should try testing the lc-1 with logworks. I bought several usb to serial adapters and they all came with a driver cd. With Vista the port will change based on which laptop usb port you lucg into so you either plug into same ports or look up port re-assignment in device manager.
LOL I just got back from Frys and I bought a self powered usb hub to try and plug Tactrix and LC-1 into hub and then only have to plug and replug into one port on laptop. We will see how this goes.
PS Fry's can sometimes be a pain to return stuff
Good Luck
Good Luck
evo4mad
May 5, 2015 06:22 PM
