Links to Valuable ECU topics
A lot of us would like the see these threads stikied. Please do it for us.
https://www.evolutionm.net/forums/sh...d.php?t=259595
JDMMAP sensor set-up by mrfred
https://www.evolutionm.net/forums/sh...d.php?t=293981
Direct ECU boost control by mrfred
https://www.evolutionm.net/forums/sh...d.php?t=288408
Fine tuning Load based boost control to prevent weather based boost variation by mrfred
https://www.evolutionm.net/forums/sh...jector+scaling
Injector Scaling by various members
https://www.evolutionm.net/forums/sh...d.php?t=249388
MAF Scaling by SophieSleeps
https://www.evolutionm.net/forums/sh...ight=byte+load
96940011 05 EVOVIII ROM: Known Patches
https://www.evolutionm.net/forums/sh...t=mivec+tuning
Mivec Tuning by John Bradley the mivec guru (Page 10 and on are more useful information)
https://www.evolutionm.net/forums/sh...d.php?t=302895
Hoiw to Tune an Evo by nj1266
https://www.evolutionm.net/forums/sh...d.php?t=297825
PATCH: NLTS + Valet + KnockCEL by Tephra
94170008 ROM 2 byte load mod for dummies (like me
by A418t81
https://www.evolutionm.net/forums/sh...hlight=dummies
Evo IX 2-byte Load & Lean Spool for Dummies by Pd1
https://www.evolutionm.net/forums/sh...d.php?t=201146
ECUflash tutorial for beginners - EFIxMR
https://www.evolutionm.net/forums/sh...d.php?t=276674
HOW TO - Control boost using ECUFLash and 3 port GM boost solenoid - Evo_Kid
https://www.evolutionm.net/forums/sh...d.php?t=227006
HOW TO - Control boost using ECUFLash and the stock boost solenoid - Evo_Kid
https://www.evolutionm.net/forums/sh...d.php?t=259494
log WGDC in EvoScan - mrfred (good info on solenoid TBEC)
https://www.evolutionm.net/forums/sh...d.php?t=327185
official 2 byte load w/ mut address - jack of trades
https://www.evolutionm.net/forums/ec...us-mrfred.html
forced obd inspection pass
Guys if you want others stickied, just add them to the list. There is so much valuable info that is getting lost w/o stickies. A lot of question are being repeated over and over again.
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
These have good info too:
While reading you kick-**** post about how to tune an Evo, I couldn't remember if I set the lean-spool disable RPM higher after I switched to the Tephra modded ROM. I'm sure I didn't once I thought about it. How about linking to the post that discusses the issue. I'm going to have to go find it right now. I believe it requires an XML edit for ecuFlash.
This post had the info that I needed. However, I still think this, along with other "lean spool", "boost enhancement", "anti-lag", etc., topics are not fully understood.
Wasn't there an ecuflash glossary floating around as well? That would be good to have up here (I can't remember if it took off and had many contributions though - I always thought it was a good idea).
I remember there being a thread that explained how to mod your ROM. That would be an excellent one to have stickied.
*EDIT* Here it is...
How to MOD your ROM with NLTS or others!
https://www.evolutionm.net/forums/sh...35#post4830835
Suggest adding this thread to the sticky:
relationship between knock sum and "octane" value
https://www.evolutionm.net/forums/sh...d.php?t=220132
