EcuFlash V1.34 released
Old Nov 7, 2007, 07:30 AM
Jorge T's Avatar
what do you mean by fine tuning of boost?
I don't use direct boost control but everything works for me on 1.31 and yes I just did a find little and replace big on both my rom xml and evo xml. I have been just transfering my xml defs from one version to another.
Old Nov 7, 2007, 07:32 AM
nj1266's Avatar
Here is the link
https://www.evolutionm.net/forums/sh...d.php?t=288408
Old Nov 7, 2007, 07:51 AM
Jorge T's Avatar
I see, I just pasted the defs on my 008 rom xml and reads allright
Old Nov 7, 2007, 08:19 PM
codgi's Avatar
Originally Posted by nj1266
Does 1.31 has any of the endian issues? I never tried it. I tried 1.30 and I could not get communication with my ECU.
Does the fine tuning of boost (not direct boost control) work with 1.31?
1.31 I believe was when the endian issues started...however personally I have no issues with it and my 2005 VIII. And yes I run the "fine tuned" one with the interval update, TBEC uses 2 byte load etc. just fine.
YMMV
Old Nov 7, 2007, 08:25 PM
Dapper Dan's Avatar
couldnt get it to work......
Old Nov 8, 2007, 06:33 AM
Jorge T's Avatar
Are you unistalling the old tactrix cable drivers? If you don't, it's possible to end up with 4 drivers instead of the 2. This may cause conflicts.
Old Nov 8, 2007, 08:12 AM
mrfred's Avatar
Assuming that this newest version of ECUFlash will run on my laptop, I'll probably go ahead and upgrade. v1.29a occasionally brings down my laptop entirely (oh the joy of Windows), and I like the recent file list in the newer versions. I think that only a few of my ROM mods are affected by the Endian bug. I'll have to look at that soon.
Old Nov 8, 2007, 09:23 AM
Dapper Dan's Avatar
i uninstalled the old ecuflash, do i have to uninstall the drivers seperatley? if so how do i do that?
Old Nov 8, 2007, 04:27 PM
Jorge T's Avatar
use control panel to uninstall tactrix windows drivers
Old Nov 8, 2007, 04:34 PM
broddey's Avatar
Been using it for a week now, no problems as of yet!
Old Nov 8, 2007, 04:37 PM
nothere's Avatar
it is fun to view the map as a 3 dimension chart. some day we may be able to bump adjustments to the chart itself?
Old Nov 8, 2007, 04:44 PM
Dapper Dan's Avatar
do all of the rom mods work on this version? i think im gonna test them out tonight..
Old Nov 8, 2007, 05:16 PM
Dapper Dan's Avatar
still cant get this version to work, any ideas?
i keep getting this when i try to read my rom
[19:15:09.562] Using interface OpenPort 1.3 Mitsubishi TX14siPbbf8ff6c900000000000000000000000000000000
[19:15:09.562] interface close
[19:15:09.578] unable to connect to vehicle interface.
[19:15:09.578] interface close
Old Nov 8, 2007, 06:15 PM
Jorge T's Avatar
did you uninstall the old tactrix drivers? the new ones are: (6/27/07 2.02.04)
Mine reads: Using interface OpenPort 1.3 Mitsubishi TX34.
I've noticed most that report OpenPort 1.3 Mitsubishi TX 14 have the ECU connection problem. Not sure if this has anything to do with it but
I also have .NET Framework 2.0 and 3.0 installed.
Old Nov 8, 2007, 06:46 PM
Dapper Dan's Avatar
im pretty sure i did....unless i did it wrong. i went in and i only saw one driver tho? maybe i looked at the wrong thing? ive never had to uninstall a driver so im not too sure if im doing it right. can you be a little more detailed?
Quick Reply: EcuFlash V1.34 released
