Let's see your fully tuned timing maps
Old Oct 3, 2012, 09:28 PM
  #1846
211Ratsbud's Avatar
lol ive been there. This thread has greatly helped me grasp my timing curve. I still feel Im missing a few areas and my ramping timing up at low loads may seem steep, however I dont get knock. I may be leaving some on the table in some areas and Im guilty of the "implying smoothness where its not present"...
a majority of the timing values in the low rpm spool are determine by eliminating knock so I was blending that in with the shift knock and eliminating the presence of that. Timing is almost linear at spool from higher rpm, vs lower rpm is curved
Old Oct 7, 2012, 02:33 PM
  #1847
Boostin_AWD's Avatar
I have been playing with the tune trying to get things squared away. Thought things were doing relatively well. Last night at the track I was getting some knock in 3rd and 4th. Ill attach the log and my ignition map. Let me know what you guys think. I know there are many of you who have a hell of alot more experience than I do. Current mods, Ets 4" core with ets upper pipe/ evo 9 dv, and buschur lower, stock viii turbo, intake (no idea whos), turbo back (no idea whos), grimmspeed 3 port, wally 255, aem uego, all of this is on pumpee 91.
Attached Thumbnails Let's see your fully tuned timing maps-my-timing-map.jpg
Old Oct 7, 2012, 11:57 PM
  #1848
3K
3K's Avatar
Originally posted by: timv
Thanks for the input.
My wife is driving the car this week so I will do some tweaks when I have the car again.
Does anybody know of a specific parameter that would affect knock @ right around 5500 rpm?
I sometimes get knock counts up to about 8 out of nowhere @ 5500 rpm.
No afr spike or timing jump. Not sure what else to consider.
That is one reason my higher rpm timing is a little lower and why I'm going to try cooler spark plugs.
Thanks again.
I had a similar problem, had 8-10 counts of knock at 5500rpm WOT only. At first it was just the cel flashing, later I started getting fuel cut and even higher knock counts. Turns out it was my wastegate slaming shut at that rpm. Not saying this is your problem but just something to consider.
Old Oct 8, 2012, 12:27 AM
  #1849
chaosfiend21's Avatar
What do you guys think about this timing map for a stock 8 block fp red turbo?
Old Oct 8, 2012, 05:52 AM
  #1850
mean4g63's Avatar
opinions on this one...where can I improve it. I have also included the VD. For some reason my VD numbers are inflated. I picked level ground, VD numbers change around 10 hp from smoothing 1 to 6, and I consistently get these numbers run after run, and my gearing is the same as the Evo 9 RS(5 speed). Anyways if anything a good reference. (note: I have added a bit of fuel in the 3750-4500 range as you see its a bit lean, and the logs only show 1 count of knock at 3200 RPM)
-JDM Evo 7
-Running 93-95 octane
-stock turbo w/10.5 hotside
-GSC S1 cams
-ETS 3.8" garret intercooler w/upper and lower intercooler pipping
-MAP o2 eliminator downpipe and AMS exhaust
-boost peaks at 29 psi from 3600-5000 RPM, and falls down to 25 psi @ 7000
Old Oct 8, 2012, 09:07 AM
  #1851
Raptord's Avatar
What's with the sudden drop to -10 at high rpm and again at high load?? Map needs some work in other areas where timing goes in the wrong direction.
-JDM Evo 7
-GSC S1 cams
That looks like a pretty good map to me. Don't know what could be inflating the numbers, do you have the weight entered in correctly?
Old Oct 8, 2012, 09:22 AM
  #1852
Raptord, I have a log posted up a few posts before this. Have some knock in higher gears at higher rpms. Any input?
Old Oct 8, 2012, 10:23 AM
  #1853
Raptord's Avatar
That knock looks to be NLTS-induced to me. Try to smooth out your timing change at high rpm, low-mid 100's load. For example, at 6500 rpm and between 160 and 180 load, you go from 21 to 14 degrees. Smooth that out to a change of no more than 2 degrees and see if it's better (lower the timing to the left of the 14, don't touch the right side, it looks alright.)
Old Oct 8, 2012, 12:09 PM
  #1854
You are the man. Ill play with it tonight. I completely thought past nlts being a contributing factor... I think I read somewhere you said you were running -10* on your launch map? How much boost are you able to build? I noticed I was only getting about 8-9psi at the line at about 5800 rpms with timing around like 5*.
Old Oct 8, 2012, 12:15 PM
  #1855
Raptord's Avatar
What turbo are you running?
Old Oct 8, 2012, 12:30 PM
  #1856
viii with 10.5
Old Oct 8, 2012, 01:35 PM
  #1857
Raptord's Avatar
You shouldn't really need launch maps all that much to spool the stock turbo, launch maps are mainly for cars with bigger turbos that are hard to spool.
Old Oct 8, 2012, 01:49 PM
  #1858
211Ratsbud's Avatar
7 psi could light my z1 255 tires up easily
Old Oct 9, 2012, 03:17 AM
  #1859
mean4g63's Avatar
yes. the car weighs 2910 pounds in stock weight. I put it in as 2900 (i have a lightweight battery), and my fat *** weighs 210 pounds. So vehicle plus me is 3110, and the tires are 265/35/18s (25.30 according to the calculator) I dont know either. Car feels good though. Car is tuned to 270-290 load point at the moment. Do you think that I should do some work to the 230-270 region? Figured I could smooth the graph out in those regions. thoughts?
Old Oct 9, 2012, 04:14 AM
  #1860
211Ratsbud's Avatar
My logs do the same thing ill get odd random negative values tossed in there.
Quick Reply: Let's see your fully tuned timing maps
