Let's see your fully tuned timing maps
Old Jun 26, 2011, 02:39 PM
  #1066
stunt2's Avatar
wondering if this timinig is too low for cruise/low loads area or is it ok ?
Old Jun 26, 2011, 02:43 PM
  #1067
lan_evo_mr9's Avatar
Way too low and hopefully that's an E85 map due to the high timing. If that's a pump gas map = no bueno.
Cruise area's should be high 30's or low 40's FWIW. What's your peak load you're logging?
Old Jun 26, 2011, 02:46 PM
  #1068
stunt2's Avatar
not E85, it's on 98 RON
hitting 240 load, @ ~ 1.1 bar
its an Evo3
what can cause that low cruise timing ?
Old Jun 26, 2011, 02:51 PM
  #1069
So you're hitting about 3-5* at peak load and hitting 14-16* up top? If you don't have knock, then more power to ya, just seems like a bit more than what normal pump gas can take
I see you're running low boost- that's probably helping with controlling the knock.
Old Jun 26, 2011, 03:01 PM
  #1070
stunt2's Avatar
hitting 2-3* at 3500-3700 on peak load and yes, 14-16 up to top
xperiencing knock mainly on spool-up and at low loads
Old Jun 26, 2011, 05:18 PM
  #1071
CMB
CMB's Avatar
Bring your cruise loads back to normal 30-35 range maybe
Old Jun 26, 2011, 05:32 PM
  #1072
Raptord's Avatar
I've been helping Stunt with his map for a week or two. That's what I did as soon as he sent me this map to look over.
Old Jun 28, 2011, 08:52 AM
  #1073
MercenaryX2's Avatar
I don't know how or why you put your timing map like that. I sent you a rom that was decent for your setup. All you had to do some logging to tune it to your load ranges.
Old Jun 30, 2011, 06:36 PM
  #1074
evo420's Avatar
deee! duh! deee! /\
Old Jun 30, 2011, 07:15 PM
  #1075
evo420's Avatar
new e85 tune
ok so here is my first atempt at a e85 map. this is based off my 91octane map and i have not yet run this on my car, i want some opinions first!
Old Jul 1, 2011, 06:29 AM
  #1076
evo420's Avatar
Help!
Old Jul 1, 2011, 07:20 AM
  #1077
Raptord's Avatar
Not familiar with tuning E85 but it looks alright to me, might want to back down 1 or 2 degrees at peak torque to start with just to be safe.
Old Jul 1, 2011, 07:32 AM
  #1078
todd6027's Avatar
check your timing at idle with a timing light
Old Jul 1, 2011, 12:39 PM
  #1079
stunt2's Avatar
can incorrect base timing be the reason of symptoms above ? meaning only on low and mid rpms ?
Old Jul 1, 2011, 01:01 PM
  #1080
MR White's Avatar
Here's my timing map:
Here's my dataloglab dyno based on the tune:
Quick Reply: Let's see your fully tuned timing maps
