Meth Failsafe and Patches
Old Jan 24, 2008, 06:38 PM
  #391
Jack_of_Trades's Avatar
If you get a free EVO IX ECU pin with every stock ID, then send em on over! lol
I just requested a free sample from JAE, hopefully I can get one at least so I have something in my hand to work with.
Old Jan 24, 2008, 06:43 PM
  #392
bnice01's Avatar
what you guys think about this (this is probably on going to help guys run ecu boost controller):
Most failsafes that comes with these alky kits has some type of a flow sensor that triggers a solenoid by a ground to go to wga pressure. well how bout we take that ground run it to IC sprayer to activate the alter map. the alternate map "hopefully" will have a less agressive boost/timing/fuel curve.
just an idea, I know you guys have a pretty good one know.
Old Jan 24, 2008, 06:45 PM
  #393
Way ahead of ya. I designed a control box that accepts 3 ground inputs, 3 +12Vdc inputs, and 3 +5V inputs which any or all of these inputs would instantly switch from the aggressive 'alky' maps to the safer alternate maps(these will be available for anyone who would want me to make them one as well). Its also great with widebands like the zeitronix unit which has an alarm output with user adjustable parameters so you can set it so if it is over 3500rpm, TPS is above 70% and the AFR is leaner than say....13:1, it triggers the output and the safer maps get used. Its gonna be sweet once we get this taken care of.
Old Jan 24, 2008, 06:47 PM
  #394
bnice01's Avatar
LOL well you are almost in luck, my closest friend is a mitsu master tech (thats for the IX pin). I have quite of bit of stock roms, almost all. but tephra has almost all I think i gave him quite a few with the last pre patch roms. always down to help ppl, esp when they do so much for the community.
I'll give by buddy a buzz tomorrow for ya.
Old Jan 24, 2008, 06:48 PM
  #395
If your buddy can find out how to get the pins cheap, he'll save us a hassle. Mitsu will only offer him the entire harness though, almost sure of it.
Old Jan 24, 2008, 06:49 PM
  #396
bnice01's Avatar
Way ahead of ya. I designed a control box that accepts 3 ground inputs, 3 +12Vdc inputs, and 3 +5V inputs which any or all of these inputs would instantly switch from the aggressive 'alky' maps to the safer alternate maps. Its also great with widebands like the zeitronix unit which has an alarm output with user adjustable parameters so you can set it so if it is over 3500rpm, TPS is above 70% and the AFR is leaner than say....13:1, it triggers the output and the safer maps get used. Its gonna be sweet once we get this taken care of.
I knew it , been using a gm 3 port to switch my mbc from to wga pressure when i have a failure. I think I have a new weekend project, and a mbc for sale.
Old Jan 24, 2008, 06:51 PM
  #397
bnice01's Avatar
I'll see if I can just buy a box of those pins, hell they cant be too much.
did you want me to get some for the VIII's as well?
Old Jan 24, 2008, 06:54 PM
  #398
I can get them for $0.08 a piece for the VIII's and I can get them individually so I'm all set there. Just see what he can do for the IX pins.
They are made by JAE (Japan Aviation Electronics) and the part # is MX7-SGC3-7000.
Old Jan 24, 2008, 07:09 PM
  #399
bnice01's Avatar
got it
Old Jan 24, 2008, 10:02 PM
  #400
C6C6CH3vo's Avatar
There might be several unused wired pins already existing in some of the connectors that you can snip at it's terminated end (spare), pull through it's harness (if it's a straight run), and depin from the ecu connector ready to repin at whatever ecu pin your interested in.
You won't even have to crimp it with whatever special tool is needed (back end of dikes ) since it's already done for you. Free mitsu grade wire too
Old Jan 25, 2008, 03:57 AM
  #401
I was thinking that might be a last resort. The EDM/JDM's probably use all of them but at least the USDM's might have some unused wires from the ICS system. I don't have a USDM IX available to test so someone else will have to check.
Old Jan 25, 2008, 05:10 PM
  #402
bnice01's Avatar
talked to my buddy today he going to look into it for us.
Old Jan 25, 2008, 05:58 PM
  #403
Thats cool, keep us posted.
Old Jan 25, 2008, 06:17 PM
  #404
bnice01's Avatar
by the way great write up jamie.
but lookin @ this pix you can remove the switch and just use the flow sensor to alter maps.
set the prepatch for something like:
>4v alternate failsafe map (clogged nozzle, etc)
>2.5v alky map (normal flowing)
<2.5v alternate failesafe map (pressure drop)
this will all depend on how your flow sensor is calibrated, but user should have the option to change those values. use a mulitimeter to measure the voltage during "normal" flow.
you can get the pressure switch from www.mcmaster.com for
3460K61
(Same as 3460K15)
Pressure Switch 20 to 120 PSI Actuation Range
In stock at $19.80 Each
I know you guys got this pretty wrapped up
Old Jan 25, 2008, 06:58 PM
  #405
bnice01's Avatar
tephra if you need 0008 room tested let me know
Quick Reply: Meth Failsafe and Patches
