Meth Failsafe and Patches
Old Jan 1, 2008, 12:26 PM
  #106
Jack_of_Trades's Avatar
So people know what pins we need to find, here's a few pics:
These are very common and are used on a LOT of other manufacturers ECU harnesses. Here is a link I found which might help someone find a donor pin.
http://www.autosoftsys.com/supra/ecuext/
Old Jan 1, 2008, 01:00 PM
  #107
Found the dimensions for the pin we all will need. We need to find the .040" receptacle on this chart.
Old Jan 1, 2008, 01:06 PM
  #108
mrfred's Avatar
Where did you get that table? I need to track down the correct pin dimens for the Evo 9.
Old Jan 1, 2008, 01:08 PM
  #109
tyco electronics. I clicked on about a MILLION things to get there so I don't know exactly how I found it. The Evo9 ECU have the same type of pins in the harness? I'd imagine it used the same sizes. There are large pins and small pins. The .070's are the large pins and the .040's are the small pins.
Old Jan 1, 2008, 01:14 PM
  #110
I found these that seem to be the same size 175265-1 at www.newark.com, made by tyco. I'm ordering 10 of them to see if they work. Another $1.22 down the drain,lol.
Old Jan 1, 2008, 01:19 PM
  #111
Richard L's Avatar
Here is a close up of the pin - unused.
Tyco 179417-1 (not lead-free) go for Jamie's part number. It is dimensionally same in all ways.
Old Jan 1, 2008, 01:25 PM
  #112
zbomb's Avatar
Jack of Trades, U have PM
Old Jan 1, 2008, 01:42 PM
  #113
Now, I just need Tephra to make me a patch to test out 94170014
EDIT: I haven't tried your alt map patches at all yet.
  #114
mrfred's Avatar
This will work for the Evo 9?
Old Jan 1, 2008, 01:47 PM
  #115
Pop out pin 64 and measure the square tip. It's probably 1.8mm x 2.3mm(or 2.5mm). To pop out the pin, take a presicion flathead screwdriver (glasses repair type) and pop up the white plastic rectangle holder on the top of the harness. It will come up about a 1/16" at the most. Its just enough to allow the pin to slide out. NExt, just take the screwdriver and lift up the plastic clip holding the pin in from the front of the connector. I hope that made SOME sense,lol.
Old Jan 1, 2008, 01:51 PM
  #116
Evoryder's Avatar
Originally Posted by Jack_of_Trades
Yeah, we were using that as a backup option but some people can keep their ICS setups and still have an auxillary input now that we did the dirty work for them
why both get dirty? You're doing a great job!
Old Jan 1, 2008, 01:52 PM
  #117
Lol, I'm trying. Its all from greed, I'm no angel. I want my alky kit working like a champ lol.
Old Jan 1, 2008, 01:54 PM
  #118
Evoryder's Avatar
Your rom ID is not 94170008? Wasn't that a standard for 03 evo's?
You're gonna be broke pretty soon
Nope...j/k...a little.
Old Jan 1, 2008, 02:00 PM
  #119
Richard L's Avatar
I send you a couple to try, just pm me your address. It will be a a few more days than inland post.
Richard
Old Jan 1, 2008, 02:05 PM
  #120
GTLocke13's Avatar
There's a crimp tool you need for these connectors too. And its gonna run you a lot more than $1.22.
http://tooling.tycoelectronics.com/pdf/65780.pdf
Quick Reply: Meth Failsafe and Patches
