Idle Quality with RC1000 cc injectors
I installed some RC1000 CC injectors today and rescaled them using the following scaling and invalid time numbers.
Scaling=850
Voltage----ms
4.69---------3.312
7.03---------2.023
9.38---------1.079
11.72-------0.641
14.06-------0.367
16.41-------0.181
18.68-------0.049
The driveabilty was fine but the idle was pretty rough and not stable, the engine was almost stalling. I know these injectors are pretty big to expect a stock like idle but I increased the idle advance to 12 degrees and rasied the target idle to 650 rpm and zero'ed out the intake cam advance at idle from my agressive mivec map.
Now the idle is very stable but still rough, like I have a mild cam or something. I still have to tweak the scaling after observing the fuel trims.
I would not expect injectors this big to idle well but do you guys get the idle to near stock? If so any tricks other than what I did? On Nissans you can't and thats where my experiance is.
Scaling=850
Voltage----ms
4.69---------3.312
7.03---------2.023
9.38---------1.079
11.72-------0.641
14.06-------0.367
16.41-------0.181
18.68-------0.049
I would think that the scaling would be the best thing to adjust when observing the trims while driving and the invalid time @ idle voltage the best to adjust when observing the trims at idle?
The scaling I have observed is 850-860ish and the latency numbers need to be a little more than double. 1.1 @ 11.7v and .800ish @ 14.06v. When I switch to even bigger injectors this next spring (1000's+ for E85)I am going to experiment with rescaling the voltage table and putting something in between 11.7 and 14 to see if it helps curve it a little better. I dont think it will make a difference, but I want to at least see.
The thing that surprised me about the latency numbers in the AEM wizard for the RC 1000 cc injectors is how low they were. Usually, the larger the injectors the higher the latency. The latency numbers for the RC 1000 injectors are lower than those for the PTE 680s.
I think it would be best to contact RC and get the latency numbers from them.
So far my scaling is 790ish and I almost doubled the invalid time. My LTFT's are now within a +5% window. I am going to screw around a little more and I'll post up my findings.
The commonly posted invalid times from the AEM wizard posted here are way off.
I didnt want my scaling to end up being this low for fear that my fuel map would be way drifted to the rich side so I tweaked somemore and I ended up using this:
Scaling= 860
Voltage….ms
4.69……..3.312
7.03……..2.184
9.38….....1.560
11.72…...1.008
14.06..….0.696
16.41……0.408
18.68……0.336
Now my long terms trims are within +- 5%. It idles fairly decently, almost stock.
AEM's wizard is way off! Do you guru's think this is acceptable?
Thank you for your help!
Scaling= 860
Voltage….ms
4.69……..3.312
7.03……..2.184
9.38….....1.560
11.72…...1.008
14.06..….0.696
16.41……0.408
18.68……0.336
goofygrin
36
Jun 27, 2017 11:17 AM
Raceghost
Jun 1, 2016 12:30 AM
