Finding load cells
2 byte load will get you the info you are looking for.
The main thing is to remember that the ECU interpolated between load cells. IF therefore you were to see a value at lets say 250 of 7, then looked at your map and noticed at the given rpm 240 was 8 and 260 was 6, there is where your 7 comes from. The rounding error and what load cell it will start to lean toward I cant remember but I generally dont worry about it as long as its not causing issues.
I wanted to know if there was a way to find the single cell that it'll end up in, since it would be more effective to modify the single cell affected then two adjacent ones.
you could also rescale your load table on the timing and fuel. look for posts on how to do that, read as much as you can if you decide to try it. I was in the 230 load range through most of my pulls so when i rescaled, i made a column 230, that way i have a little more control over the numbers in the range my car see often. seems to have helped me a bit for staying out of knock due to interpolation. keeping numbers in adjacent cells close helps too.
[QUOTE=sllt1776;5224235]you could also rescale your load table on the timing and fuel. look for posts on how to do that, read as much as you can if you decide to try it. I was in the 230 load range through most of my pulls so when i rescaled, i made a column 230, that way i have a little more control over the numbers in the range my car see often. seems to have helped me a bit for staying out of knock due to interpolation. keeping numbers in adjacent cells close helps too.[/QUOT
I didn't think of that, good Idea. I'm gonna try it and see if the adjacent cells don't get affected in different conditions. Thanks
