Evoscan Logs
I've haven't been in direct contact with the car so the answer is no. Seeing as how roms need to modded for 2byte load and 2byte rpm I though it might apply for JDM MAP as well...ireesepctive of being JDM or not.
rolly1818...make sure to log JDM MAP as well next time so we can see what boost you're hitting.
Registered User
no problem R. Mutt..
will do but in work now.. so will have to do tonight.. (working till 7pm)
so let me get this clear, log the follwoing:
1. Throttle position
2. timing advance
3. JDM Map
4. Injector Pulse Width and Duty %
5. Coolant Temp
6. Knocksum
7. AFR Map
and which or all of the following:
8. Load MUT 2 byte Mod? or Air Flow 2 byte Mod? or RPM MUT 2Byte Mod?
2. timing advance
3. JDM Map
5. Coolant Temp
6. Knocksum
7. AFR Map
none of 8 for now since we're not sure it works on your rom...
I log:
Coolant Temp (To make sure my logs were at appropriate temperature)
Throttle Position
Engine RPM
Timing Advance
Oxygen Sensor
Injector Duty %
Battery Level
Load Calculated
JDM MAP (If you have it which you do)
Knock Sum
AFR Map
External Wideband (if you have one)
These are the basics to get you a good log. I tend to do 2-3 back to back logs as the first one gets the turbo nice and hot and the 2nd log will be more accurate than the first one.
Good luck Mate...
I log:
Throttle Position
Engine RPM
Timing Advance
Oxygen Sensor
Injector Duty %
Battery Level
Load Calculated
Knock Sum
AFR Map
Good luck Mate...
rolly1818, download this zip and reflash to the rom named New_2byte_mod.
The fuel and timing maps are more conservative and it will allow you to log 2byte load in evoscan.
Registered User
ok will do, do i need to move 89980000.xml to C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi?
and which do i log?
and which do i log?
the stuff you logged before plus Load MUT 2 byte Mod.
Registered User
i am going to log load tonight and will post up the results.
from there i will see what i need to do judging from the results posted by you guys.
