evoscan 2.1 problems and fixes
Old Feb 22, 2008, 02:07 AM
Jack_of_Trades's Avatar
Ahh, well I'm pretty sure someone said that the 1 byte RPM can only go to 8000rpm. If thats so, 8000rpm/256(1 byte)=31.25 per increment. What does the 2 byte RPM max out at? 2 byte would be 65536 I believe so it'd be [max rpm]/65536(2 byte)= ? per increment.
Old Feb 22, 2008, 02:20 AM
Another thing. For MUT 2byte RPM the formula is 31.25*x but isn't it supposed to be 1000*x/256? I'm pretty sure I came across this before and also that is you didn't put the * in the formula, it doesn't work right.
Old Feb 22, 2008, 03:46 AM
tkklemann's Avatar
What about the fuel trims? (Fuel Trim Low/Mid/High)
The current formula is => 0.78125*x
Isn't the correct formula => (.1961*x)-25 ??
Old Feb 22, 2008, 03:51 AM
That is correct as well. Man, whoever wants to use 2.1 has a good list of things to edit before logging for the first time,lol. Its all a one time change though, after its all said and done you won't have to do it again. Until the next upgrade,lol.
Old Feb 22, 2008, 05:20 AM
rish197's Avatar
Originally Posted by Jack_of_Trades
Injector Duty Cycle Formula:
Incorrect = .256*[InjPulseWidth]*31.25*x/1200
Correct = [InjPulseWidth]*31.25*x/1200
Simply remove the .256*
How is this formula different from the IDC=IPW*RPM/1200? I've always used the other one to calculate IDC%?
Sorry for the n00bie question.
-Jason
Old Feb 22, 2008, 05:29 AM
rish197's Avatar
Nevermind, I got it. Haven't had my coffee yet.
rpm = 31.25*x
rpm RequestID =21
Old Feb 22, 2008, 06:09 AM
mrfred's Avatar
I looked back at my notes, and the scaling factor for 2-byte rpm is 3.906.
Old Feb 22, 2008, 08:41 AM
cladden's Avatar
What is the RequestID for [InjPulseWidth] ?
Thanks in advance.
Old Feb 22, 2008, 10:42 AM
rish197's Avatar
Thanks in advance.
29
Old Feb 22, 2008, 01:47 PM
-Jason
The "corrected" formula I posted is technically the exact same as the one you use. Instead of referencing off of the RPM chart they just reference off of the 'x' value directly. Same outcome either way. In v2.1 he just accidentally added the ".256*" part.
Honestly, the best way to do this would be to do the MUT_2byte_RPM mod and use this formula:
IDC= [InjPulseWidth]*[RPMMUT2Byte]/1200
By doing so, you're making the Fuel Consumption rreadings far more accurate too since it will calculate off of the improved IDC readings.
Old Feb 23, 2008, 10:35 AM
kreionic's Avatar
I am not using the MUT tables. Can someone post up the formula for 2 byte rpm and what the numbers are that need to be changed. I added 2 byte load and 2 byte airflow this way with just the formula and then changed my numbers in ecuflash. Or is 2 byte rpm a MUT table thing only?
Old Feb 23, 2008, 12:23 PM
xpro's Avatar
does anyone know why i cant change com port numbers in evoscan.It stays in com number 1,so its telling me access denied,im trying to switch to port com2,cause i have it set up so in device manager,but evoscan stays in com1.im gona burst this laptop
Old Feb 23, 2008, 12:36 PM
kreionic's Avatar
what issues are you having. In all the evoscan I never had to change any com ports besides the wideband one. What issue are you having with v2.1? Does it time out when you start logging?
Old Feb 23, 2008, 12:42 PM
xpro's Avatar
i never had any issues with previous version,but with this one its telling me unable to open port com1.access denied.Then i changed open port com to number 2,but evoscan is not allowing me to change com ports even tho there is an option for this.
Someone here mentioned that if you getting message "unable to open port com1"
to try changeing ports in device manager.
thanks
Old Feb 23, 2008, 12:44 PM
kreionic's Avatar
Fair enough. its just odd that some are having issues and others aren't
Quick Reply: evoscan 2.1 problems and fixes
