evoscan 2.1 problems and fixes
#51
(0.1961*x)-25
make sure you enter the 0 before the decimal place.
I use this for my IDC's and it works fine as well. Gotta make sure you are logging InjPulseWidth and RPMMUT2Byte correctly though since that what it uses to get your IDC values.
#55
Copy and paste this in exactly. IT works just fine, I log with it with v2.1 all the time.
(0.1961*x)-25
(0.1961*x)-25
#59
- Listed above (hgher up on the list) the parameter thats referencing it
- The referenced paramter needs to be checkmarked and datalogged
Also, update your Estimated Torque formula to:
([WHP]*5252/[RPMMUT2Byte])
Using Estimated Torque as an example, you would need RPMMUT2Byte and WHP checkmarked as well as anything those parameters are referencing too.
WHP references LBSMIN so that needs to be checked
LbsMin references g/rev and RPMMUT2byte so those need to be checked
g/rev references LOADMUT2byte (or Load calce depending on which you are using) so that needs to be checked.
The first thing referenced needs to be the highest on the list...working its way down to Estimated Torque. Hope that helps.
#60
my list goes as such: do I have something out of order? lol I didnt even see the bottom of your last post. I have all checked, and I believe them to be in proper order
2byte rpm
2byte load
2byte airflow
jdm map
timing
w/b ...unchecked as I dont have a w/b.
knock sum
IDC
IPW
Inj.latency
speed
est.g/rev
est.lbs/min
est.hp
est.tq
fuelcons.
octanelevel
wgdc
load error
coolanttemp.
airtemp.
2byte rpm
2byte load
2byte airflow
jdm map
timing
knock sum
IDC
IPW
Inj.latency
speed
est.g/rev
est.lbs/min
est.hp
est.tq
fuelcons.
octanelevel
wgdc
load error
coolanttemp.
airtemp.
