2byte AirFlow 88840016
If you are using full MUT table definition (look here) find the MUT04 and MUT05 entries; else if you are using single MUT definitions in your xml insert this:
In MUT04 put 0x6B7E (hex)
In MUT05 put 0x6B7F (hex)
Scaling in Evoscan is 6.29x/64.
Code:
<table name="MUT04 2-byte Airflow MSB" category="MUT" address="3780a" type="1D" level="1" scaling="Hex16"/> <table name="MUT05 2-byte Airflow LSB" category="MUT" address="3780e" type="1D" level="1" scaling="Hex16"/>
Nuked
Jun 2, 2008 06:32 PM
