EVOSCAN 2.1 Maptracer Problems!
Old Feb 9, 2009 | 08:37 PM
  #31
raasfaas's Avatar
Originally Posted by b16a95eg
i still couldnt get the map tracer to work, it wouldnt let me right click the graph and download my .hex ( i think thats what the name was) it just does nothing....
That's strange, and you're right clicking on the bottom table right?
Old Feb 9, 2009 | 09:01 PM
  #32
b16a95eg's Avatar
i restarted my computer, and after that i could right click down there? weird
Old Feb 9, 2009 | 09:07 PM
  #33
b16a95eg's Avatar
now the only problem is that on my little mini computer i cant scroll down enought to see the very bottom of the map that loaded up
Old Feb 9, 2009 | 09:17 PM
  #34
raasfaas's Avatar
hmmm...you should be able to scroll down, you try maximizing the table?
I'm still using my 15" laptop so no viewing problems here
Old Feb 9, 2009 | 09:44 PM
  #35
b16a95eg's Avatar
it only goes up to 6500, and there's no scroll down function on the right side.... or maximize, just the x to close it out in the top right
Old Feb 10, 2009 | 06:19 AM
  #36
raasfaas's Avatar
in the top right beside the x (anywhere on that grey area) just double click and see what happens.
Old Feb 10, 2009 | 06:32 AM
  #37
b16a95eg's Avatar
it just filled up sideways when i maximized it lol
Old Feb 10, 2009 | 06:48 AM
  #38
MR Turco's Avatar
Originally Posted by MR Turco
I posted this in the 2.6 thread but it might get answered here. Here is my problem:
I have to be doing something wrong. I for the life of me cannot get maptracer to work in 2.5 or 2.6 beta 7. I did notice in beta 7 the autoload is looking in an obscure folder for my .xml. I have one in there but it was like an old one that doesn't work. I replaced it with a working one and maptracer seems to load properly but when i click on parameters the top table displays nothing.
Is there a way to change where it looks to autoload the .xml? Am i doing something wrong?
ok so i realized the sample logs work but not one of mine do regardless of size or content. WTF?
Old Feb 10, 2009 | 05:56 PM
  #39
b16a95eg's Avatar
mine too, i just realized too, whats wrong with it? i click knock sum and nothing comes up from my logs, i go to load my xml too and i click it and nothing happens, whenever i start up maptracer the table below always starts with 7.4 timing on the timing map, then i click it and it changes, i click the knocksum on the side and nothing comes up on top, anybody know why?
Old Feb 11, 2009 | 01:22 AM
  #40
evodziobak's Avatar
Originally Posted by raasfaas
evodziobak: you have to load your current XML and HEX/BIN file for it to show properly. Right click on anywhere in the bottom table and then select "load xml/hex file." Make sure you select the xml file associated with your romid and the hex file that is currently running on your ecu.
Hope that helps.
yeah that helped. thanks.
Old Feb 11, 2009 | 01:30 AM
  #41
evodziobak's Avatar
just like raasfaas said be sure to load the xml associated with your rom version, then map tracer asks you for the hex file. browse and load the hex file you downloaded with ecuflash from your ecu. after that you should be able to see your current maps in the bottom table and that way you can compare them to what you have logged. be sure to log knocksum. you need to check knocksum
in the main evoscan screen in order to logg it. i don't think it's checked by default.
Old Feb 11, 2009 | 06:31 AM
  #42
b16a95eg's Avatar
i'll try that out, thanks guys
Old Feb 11, 2009 | 06:40 AM
  #43
b16a95eg's Avatar
ok so it still didnt work, maybe i'm doing something wrong. I open evoscan v2.5, click the map tracer, its completely blank, i right click the very bottom graph, i load my xml from ecuflash (91470015 pretty sure the first 4 numbers are in the right order) then the window flickers a little bit and its still the window but now it says load .hex or .bin, so i go into my desktop (thats where i saved it to so i could find it) and i load my .hex that i uploaded to my ecu last night, then the window closes and my values show up in the bottom map. i click knock sum, and nothing happens. did i miss anything?
Old Feb 11, 2009 | 06:53 AM
  #44
MR Turco's Avatar
I am having the EXACT same problem. I opened a ticket on EVOscan's website. Hopefully i can get this fixed. doesn't seem to work in 2.6 beta 7 either.
Old Feb 11, 2009 | 07:56 AM
  #45
b16a95eg's Avatar
ok so i'm not the only one, i'm not doing anything wrong am i?
Quick Reply: EVOSCAN 2.1 Maptracer Problems!
