EVOSCAN 2.1 Maptracer Problems!
Hey guys im having problems with maptracer. Basically i load my xml and load my bin from ecuflash and everything loads up and i can see all my timing and fuel setting in the bottom window but nothing shows up in the top window. It doesn't matter what i check in the left side column nothing ever shows up in the top window. The weird thing is i can log the Sample logs that comes with EVOSCAN and load the same xml and bin file and maptracer works perfect. Has anybody figured out the fix for this yet? My ECU ID is 94170008 and im using EVOSCAN 2.1.
Thanks in advance!
Chris
Thanks in advance!
Chris
attach it to a support ticket at www.evoscan.org/helpdesk/ and I'll take a look, its probably just an old xml file that has different map names.
thanks for all the help so far guys. I opened a ticket up and sent him all my files so hopefully we can get this resolved soon. Would be a great tuning tool if it worked!
Chris
Chris
I ran the logs from the 94170008 logs from yesterday through the v2.1 map tracer and all works fine. IDK I havent encountered any of the issues people are having with evoscans.
I personally dont use map tracer much but every log I have done from 2.0 and 2.1 all worked in map tracer without any issues
Thanks
Chris
You need to post the exact procedure that you are using. E.g what xml are you using for ecuflash? Are you using the rom xml from evoscan, ecuflash, etc?
Even though Jack of all trades said my explanation does not work I really feel that evoscan does not do well when you use xml that is modded. Check your 2 byte RPM formula. I found that evoscan was using the 2 byte rpm rather than the regular RPM.
Follow my proceedure and I bet it will work! I had the same symptoms that you did.
I am posted the log file that we are having problems with. CHMODLF can you please download it and see if it works on your computer?
P.S. I can load my xml and my rom in evoscan along with the sample log provided in evoscan and the maptracer works fine.
Thanks
Chris
