How do you run 24.5psi on 91 oct???
Old Feb 26, 2008, 08:42 PM
Jim in Tucson's Avatar
I've been following with great interest razorlab's thread on Well set-up ECU-controlled boost. I've been most impressed with the 24.5psi spike on 91 octane. Awesome!!!
I realize this was on a IX and I have an VIII, but where is the weak sauce in my set-up?
My mods are:
K&N drop-in
Hallman MBC (21psi spike tapering to 18psi)
IX bypass valve
Helix down pipe
Helix test pipe
Greddy EVO2 cat-back (modified)
HKS 264/264 cams
Nisei LICP
Walbro 255Lph fuel pump
IX turbo
PPI ported ex manifold
SS O2 housing
318whp/311trq on MD (prior to Mellon Tune and FMIC)
Mellon Tuned
ETS 3” FMIC
Any suggestions???
Thanks,
Jim
Old Feb 26, 2008, 09:09 PM
tephra's Avatar
Have you tried running more boost?
Old Feb 26, 2008, 09:13 PM
lemmonhead's Avatar
i only have a full 3" TBE. I had trouble holding 25psi on 92 gas(had 2-3 counts of knock). I had to retard timing way to much for my liking to get rid of knock, BUT i also had a very aggresive MIVEC map. In the end I reduced my MIVEC in the 240-300 load range and was able to increase my timing back and hold 25 psi, 20-21psi redline.
I say fiddle with the MIVEC a bit keeping all else same and see if it helps.
Old Feb 26, 2008, 09:21 PM
ChuckP's Avatar
My mods are:
K&N drop-in
IX bypass valve
Helix down pipe
Helix test pipe
HKS 264/264 cams
Nisei LICP
IX turbo
SS O2 housing
Mellon Tuned
ETS 3” FMIC
Any suggestions???
Thanks,
Jim
Have Razorlab tune you car?
But seriously, all evos are different. And im pretty sure he mentioned this was a "freak."
Old Feb 26, 2008, 09:26 PM
RazorLab's Avatar
Received 1,056 Likes on 764 Posts
Evo 9's are much much much more tolerant to boost than Evo 8's from my experience. I contribute it to the head design and mivec.
Yours looks like a pretty solid setup. If you want to hold more boost up top, look towards ecu-controlled boost and a upgraded actuator.
Old Feb 26, 2008, 09:29 PM
Wicked E's Avatar
The advantage is having the IX block with MIVEC...
Old Feb 26, 2008, 09:36 PM
tabio42's Avatar
It might also be falsely showing knock because the knock filters get more sensitive as the boost goes up. Like picking up engine noise.
badhabit90's Avatar
Talking
uhhh...reading comprehension is good here...hehehe
Old Feb 26, 2008, 09:37 PM
codgi's Avatar
His is an VIII so he has no MIVEC .
Old Feb 26, 2008, 09:52 PM
JohnBradley's Avatar
Timing is irrelevant to a point. After reading what Mark Shead had to say in the Magnus intake manifold thread (before it disappeared), I decided to go out and try running as much boost on pump without knock as possible. I also log WHP as a function of load so I can quantify changes.
Best with 25-22psi and timing ranging from 2-3* to 14* by redline was 375whp
Best with 28.9 tapering to 25 and timing going from 0* to 9* was 405whp. I dont have an EGT probe, but there was also no knock. I have one log from testing running that level of boost but there was some knock but not till it tapered to almost 23 (that was just a simple miscalculation).
cliffs- drop timing, keep AFR's where you want them, raise boost...profit?
Old Feb 26, 2008, 10:07 PM
tephra's Avatar
so boost is better than timing?
so the golden question, how much boost is safe for a street car (23 to 20?) and how much is safe for a track car (19flat?)
Old Feb 26, 2008, 10:14 PM
DrivinMissDaisy's Avatar
My car boost spikes at 25psi at 3.5k and then tappers down to 19 at redline. I have no knock. I even raised timing to *5 after spool to 11 at redline. I run 91 **** water.
AFR's are 12+ during spool and drops to 11.1 by redline.
Old Feb 26, 2008, 10:26 PM
EFIxMR's Avatar
hardcore
Old Feb 26, 2008, 10:32 PM
RazorLab's Avatar
You might be interested in this post (which references the 1st post in the same thread):
https://www.evolutionm.net/forums/sh...88&postcount=6
Old Feb 26, 2008, 11:19 PM
Bryan I had seen that thread and I decided that I am going to go back to ECU based boost control. I havent had very good luck with the factory BCS and the Green, the Hallman I am using now was touchy till I rebuilt it, but that boost curve is exactly what I would like to be able to do.
One more project to add to the list of things I need to do to my own car
COP,
Bigger Cams,
Meth,
MAFT PRO,
3 Port,
etc.
I apologise for the threadjack, but it seemed relevant to discuss boost vs timing again.
Quick Reply: How do you run 24.5psi on 91 oct???
