Setup to active immobilizer with my key!
Hello! My problem is that with a key false of the car the engine start(With any copy key), my immobilizer this off. As could connect again? I have the correct code immobilizer in ecuflash and init-code to 0001 (All extract the my original ECU). Help me please!
Sorry my bad english, i'm spanish boy and in spain very bad information for this car, i need your help.
The problem is that the car starts with any duplicate key. I just want that there will be with the originals. I need start immobilizer for only start with original key, not with any duplicate key.
That isn't actually a piece of cake you know. If you don't have the correct immobilizer code in your ECU then no key will start the car. If your confident that the key and immobilzer code you got in the ecu are matching all you need to do is enable it with ecuflash.
In other words you want to enable the immobilizer. I'm assuming right now you have disabled the immbolizer through the use of the periphery in the MUT table.
In the Workshop-mitsubishi denied access to the immobilizer with softare Mut III.
active, code, ecuflash, engine, evo, immobiliser, immobilize, immobilizer, immobilizers, immobolizer, init, install, ix, start, switch, tumbler
