SAS Hardware
#31
After a nights sleep, 4 cups of coffee, and talking to my research group (aka the fam) it seems I did in fact have a drizzle as far as using the BDEL maps to control the vacuum source. Wont know for a 100% till I try but I dont think its gonna work how I originally thought.
#32
I just had the same brainstorming, facing my VII and IX in the garage.
The first one is fitted with all the stuff, the second one is not.
I'm still wondering what is the solenoid on the FPR line made for, it's already there on the 7.
I always thought it might be something related to lean spool (as closing this one will keep fuel pressure lower)... maybe this one can be used for a different purpose.
Worth a try.
Looking at the 7 plumping, I also noticed something strange to me : with solenoid open, the SAS valve should only open on vaccum, and closing on manifold pressure.
So that this ALS should not build boost in the manifold...?
Any experience there ?
Worth a try.
#33
the way its supposed to work is when the intake manifold is pressurised then the throttle plate closes when you lift off, the intake manifold goes into vacuum but the other side of the throttle plate and also in the boost pipes is still under pressure this is where the dump valve opens and recirculates the boost,
remember the dump valve needs a vacuum to operate also, so the sas valve opens and dumps the boost down into the exhaust manifold,
it is supposed to operate at the same time as the dump valve and keep the turbo spooling,
#34
#35
no not necessarily if the settings are correct the sas will kinda act like a dump valve also. except dumping the boost into the exhaust manifold and not to air or recirculating it and it then keeps the turbo spooled,
i think at the same time as the sas opens and dumps the boost the timing is supposed to get retarded and some extra fuel is injected so there is a charge and not just boost going past the turbo and this ignites and hey presto antilag,
I need to do some testing tomorrow but it looks like the sas might be opening but the rest of the process is not happening,
#38
going to see what happens when I connect the sas directly without the ecu valve,
theoretically it should just act as a smaller dump valve and the dumped boost will spool the turbo along with the retarded timing and extra fuel,
#39
One thing I am wondering is if the ECU knows to ignore any knock this would generate in the factory subroutines. Since we are intending to bypass them, there is a possibility of some noise getting through. Not that it matters cause lower timing helps us in the long run, but a thought I had earlier today.
#40
#41
Could being a flaming ricer be a solution to making antilag work? Next on evom news at 11...
Honestly I have a problem with coasting fuel cut in my car that almost feels like ALS. And I think it directly correlates to the VTA bov.
#43
I've been reading this and trying to follow here. I'm wondering if the vacuum canister and solenoid work similiar to the one on 94-01 integra gsr's who use vaccum to open secondary intake manifold butterflies. Just wondering if you
could source parts from them cause you could find them everywhere.
#45
Youngsyr, I am actually pretty taxed with a few projects lately. SoCalRedLine expressed interest to test this out as well. If he agrees, I would like him to take my spot to test out the hardware. In the mean time, I will keep chugging away on the software and provide support to both SoCalRedLine and JohnBradley on that side of things.
