PATCH: TephraMod V5
#242
I do not have a JDM MAP sensor so I won't be able to test things related to that. I AM using GM BCS, and alt-maps works for fuel, timing, and bcs, this is confirmed on my car. And yes, dropping load threshold to 50 for nlts works awesome, just like it did before.
Maybe I should pick up a 3 bar map sensor, I've been wanting one anyways.
#255
EvoM Community Team
I really don't think this is a bug as much as just something that would be tweaked. With 100 load you should be able to rev fine, and you can hit that load pretty darn easily. It may be wise to change the defaults down to 100 in the bin files though.
Originally Posted by tephra
2) apparently - just plug it in and log MUT38, no need for table changes to fix the 1bar -> 3bar MAP
I'm all down for doing whatever is needed for PSI based boost control on 88590015. Please let me know if there is anything I can do to help, I'd like to have it set up by the 8th for my tune. FYI for anybody looking to get one, Mrfred said that he has another batch of JDM sensors coming in (hopefully) this week!
