PATCH: TephraMod V5
Old Apr 10, 2008, 07:15 PM
  #421
tephra's Avatar
for 88570008 specific information please see the following thread, once everyone is happy with the proposed solution i'll put information in the main v5 thread (ie this one).
https://www.evolutionm.net/forums/sh...d.php?t=328279
Old Apr 11, 2008, 10:46 AM
  #422
SoCalRedLine's Avatar
Originally Posted by tephra
what do you want 4.2 for?
rofl... cause im collecting ROM files for fun, DUH!
Old Apr 11, 2008, 12:19 PM
  #423
mlocatel's Avatar
Rom 88840016/88840017
Hello Tephra.
sorry for asking, but can you anticipate when this ROM will be patched?
Thanks for the info
mlocatel
Old Apr 11, 2008, 02:10 PM
  #424
lemmonhead's Avatar
tephra with your new ROM is it ok to rescale, i want my map to go to 320 like before?
Old Apr 11, 2008, 02:55 PM
  #425
Jack_of_Trades's Avatar
Perfectly fine to rescale your load or RPM axis'.
Old Apr 12, 2008, 10:00 AM
  #426
EvoM Community Team
fostytou's Avatar
Originally Posted by kayman
Suggestion: Was thinking if you can make NTLS enabled when ALT Maps gets enabled? dont know about others but when driving round town day to day i dont like using NTLS and on the ocasion like to have a bit of a hit and forget about NTLS and the car goes jerk jerk so was thinking NTLS is more so for going quick and I supose you would want to use it with your QUICK (alt) map so perhaps enable them together? or maybe have a switch to say Enable NTLS with alt map?
I think alot of us will still want NLTS on the base map. If it is really an issue for you set the threshold a bit higher (I use 100, rather than the 50 that Jack recommends and have never had an issue).
In any case, you shouldn't be resting your foot on the clutch pedal. Its a bad habit that should probably be corrected on the user side and not the car side
Old Apr 12, 2008, 12:08 PM
  #427
kkarim's Avatar
Originally Posted by mlocatel
Hello Tephra.
Thanks for the info
mlocatel
+1
Keep up the good work teph... :P
Old Apr 13, 2008, 04:54 PM
  #428
kayman's Avatar
Know exactly what you mean, I dont rest my foot on the clutch i know its very bad it comes straight off .. but sometimes my clutch foot is a bit quicker then the acccel foot and starts to push in before the accel is totally off and it jerks.... I have mine set to 98% I can easily adjust and learn to wait on the clutch foot but i thought it might be a handy feature... wasnt asking it to be done just for me but more so a extra feature that could be good.
Was just thinking it might be easy to set a tick box for activate NTLS on ALT MAPS SOOO if NTLS was not enabled when ALT MAPS was enabled and the tickbox to say enable ntls was set then it would enable ntls as well... however if ntls was already enabled then it would do nothing if you get what i mean. Just a thought, and i supose same backwords once ALT is disabled NTLS also dissables with it, if it was previosly disabled.
Old Apr 14, 2008, 02:14 PM
  #429
nano's Avatar
been testing 88590015 in my car since it has been released and things are working good except when you come out of load during nlts it bugs out and reverts to the other rev limit.
i havent tested alt maps yet though. only nlts and valet.
question for tephra though. would it be possible to, instead of toggling valet mode on and off via 100% throttle before ign. could it be changed to toggle NLTS?
once again tephra, thanks for everything and how much hard work youve put into this.
Old Apr 14, 2008, 03:09 PM
  #430
Wicked E's Avatar
My car did NOT like the V5. I copied everything over to the new rom. Got 25 counts of knock and 12.9 AFR. Something was amiss so I reverted back to the previous version and everything is candy.
I'll mess with it more when my tune is done on the current version and try again with V5.
Cheers-
E
Old Apr 14, 2008, 04:02 PM
  #431
tephra's Avatar
what ROMID wicked?
Old Apr 15, 2008, 02:56 AM
  #432
sub7's Avatar
A big thanks to tephra! I'd just flash 90550001-v5 into my e7 JDM (previously 98640014). Bump into some problem, NTLS TPS Threshold not allow any input or display any value. Here's the screenshot.
Did it happen to everyone or just me, or it's a known issue?
Old Apr 15, 2008, 05:23 AM
  #433
jcsbanks's Avatar
You have a missing throttle percentage scaling, my ROM was the same. The scaling is *100/255, 16 bits.
Old Apr 15, 2008, 09:48 PM
  #434
sub7's Avatar
Thanks JCS, the scaling for tps work! Bump into another trouble, the car jerk at 4000rpm, feels like rpm cut. When compare my old jdm boost limit vs tephra, the scaling is only set to 4000rpm. Anyone have a better scaling for boost limit? Anyone had similar problem rev above 4000rpm?
Last edited by sub7; Apr 15, 2008 at 11:49 PM. Reason: Rectified rpm cut, not boost cut
Old Apr 16, 2008, 05:12 AM
  #435
MR Turco's Avatar
Cheers-
E
Where were you seeing the knock? Tephra i believe he has 88590015
Quick Reply: PATCH: TephraMod V5
