PATCH: TephraMod V5
Old Apr 16, 2008, 06:31 AM
  #436
Oracle1's Avatar
Any updates Dave?
Sorry for being inpatient...
SK
Old Apr 16, 2008, 07:09 AM
  #437
tephra's Avatar
me and john are just finalising the code so that it will integrate a bit nicer with the live mapping stuff john is working on
be out very soon
Old Apr 16, 2008, 08:41 AM
  #438
Wicked E's Avatar
Originally Posted by MR Turco
Where were you seeing the knock? Tephra i believe he has 88590015
Correct on the romid.
My wife and I just had a son this morning, so I won't be able to get to your questions till this weekend. I did get your PM and will send you the log when I'm home this weekend...
I was seeing upwards of 25 counts of knock from low load areas all the way to WOT with high 12 AFR's... Reverted back to a pre-v5 rom and the knock went away. 0 counts of knock with perfect AFR in the mid 11's. Same maps between both roms.
Cheers-
E
Old Apr 16, 2008, 08:47 AM
  #439
lemmonhead's Avatar
how can that be? if you had the same fuel/timing,mivec as your original ROM how can his ROM V5 cause all those knocks?all he did is make it so the maps are combined into 1 for timing and boost tables.
anyone else experience this problem?
Old Apr 16, 2008, 10:01 AM
  #440
MR Turco's Avatar
I did notice high counts of knock in higher gears in low load <100. It is all part throttle in what i would call i-should-downshift-areas. The problem is i cant find any logs of those areas PRE v5. I am considering loading on a pre v5 map and seeing what i can find.
Old Apr 16, 2008, 10:35 AM
  #441
lemmonhead's Avatar
damm more than 1 person having issues, makes me kinda scared and wanna ditch it also. Maybe the saftely filters of the OEM are compromised by accident.
I dont wanna find out the hard way.
Old Apr 16, 2008, 10:48 AM
  #442
MR Turco's Avatar
it doesnt make sense though because i think such high knock counts would be audible whether by tinging or the rod through the block.
Old Apr 16, 2008, 11:21 AM
  #443
turboracer's Avatar
No problems running 88590015 patch here.
All conditions seem to work fine except did not test on alt maps. I dyno the car yesterday on this patch. No knock AFR right where they were before the patch.
Old Apr 16, 2008, 11:40 AM
  #444
ohhgyeahfasho's Avatar
im not sure if this is related but recently after i had installed v5 rom, in 2nd gear i've been getting knocks on low load up to 6 counts of knock.. i decreased timing by 1 on those areas..and still getting up to 4 knocks..on my previous rom i wasn't getting knocks in these areas..hmm im still tinkering around to see if it will go away..
Old Apr 16, 2008, 12:06 PM
  #445
Wicked E's Avatar
Seems like you're not the only one...
Cheers-
E
Old Apr 16, 2008, 12:08 PM
  #446
lemmonhead's Avatar
da da da da, the plot thickens.
Old Apr 16, 2008, 12:23 PM
  #447
RazorLab's Avatar
Received 1,056 Likes on 764 Posts
Just tuned a Evo 9 the other day with 88590015. Checked in all gears.
Seems ok to me.
One thing I did do that others might not have is I still changed all the different maps you usually do when not using V5. (3 timing maps, 3 boost maps)
I did it out of habit.
Old Apr 16, 2008, 12:44 PM
  #448
Racexerxes's Avatar
Hi has a Tephra been created also for this ROM? 88840013
This is for the Euro EVO IX GSR.
Thx
Old Apr 16, 2008, 01:28 PM
  #449
EvoM Community Team
fostytou's Avatar
I posted a few pages back that I was getting a knock warning in 5th at low load between about 2500-3300rpmish... but not always. I felt no reduction in timing and didn't see boost coming down at all, so I figured the ECU was just filtering and the flash mod was still displaying it even though the ecu seemed to not-react (because it was filtering it) I've never seen a >8 count in this situation. its probably once a day on the highway, but not too often (28 miles each way through a bit of traffic)
Old Apr 16, 2008, 01:35 PM
  #450
Wicked E's Avatar
Seems ok to me.
In a sense you're saying that you did NOT delete #2 and #3 respectively as quoted in the instructions? You just left them in there and copied Map #1 to the #2 and #3 anyways?
Cheers-
E
Quick Reply: PATCH: TephraMod V5
