PATCH: TephraMod V5
#451
I posted a few pages back that I was getting a knock warning in 5th at low load between about 2500-3300rpmish... but not always. I felt no reduction in timing and didn't see boost coming down at all, so I figured the ECU was just filtering and the flash mod was still displaying it even though the ecu seemed to not-react (because it was filtering it) I've never seen a >8 count in this situation. its probably once a day on the highway, but not too often (28 miles each way through a bit of traffic)
#452
that is what I did also, i didn't delete nothing, i just copied all maps the same.
I didn't want a situation where the ECU wanted to look at a map block and have nothing there going in infinite loops or whaterver, LOL
#456
Good point! Make sure if you had lean spool off before, it's off again when you move to the V5 rom.
I had a customer last week move to a V5 rom by himself, he forgot to turn lean spool off, like it was with my tune.
I put it on the dyno this week and it was 12.1 AFR, 1 full point leaner than what I had tuned him to with lean spool off.
of course my question to him was "How long have you been driving it like this?"
#457
did some more testing on 88590015 today.
did a hard run real fast. quick nlts from 2 to 3 and let off after that because i had come to a red light. light turns green put it back into gear and gave it some gas......bogged from 1200 rpm to 1500 like it was hitting a rev limit at 1500 rpm. turned off car, turned it back on -- same thing. reflashed the rom and was fine again.
#459
Hi ,
We have problem on evo VIII , EUDM , with 96530006 .
One friend have tested the tephra pack V5.1 , for the moment it's ok .
A second friend have an evo VIII EUDM two , and there's problem...
The Evo start , 1 or 2 seconds , on idle , and cut . Even with all tephra mod options check on " disable " .
Any idéa ?
Edit :
The map is based on FQ300.
When it flashed with the stock 96530006 rom , it's ok , the car start , drive , etc.
Now , with the tephra V5.1 pack , the car start , and stop.
In this configuration , it's impossible that is it a NLTS , valet , etc tune problem , isn't it ?
So , in fact , it must be the same map as the stock rom , but with just one boost desired engine load , and one duty table...
The IMMO code is ok !
Edit ² :
Agron25 evo's who have NLTS use an AVCR.
My friend use stock boost gestion.
So , we delete boost table 2 , 3 and 4 , and duty table 2, 3 and 4 . It's not a reason to don't start , but , think you that it's related ?
Any idéa ?
Edit :
Edit ² :
#460
Hi ,
Any idéa ?
Any idéa ?
#465
Dave,
Can you put the V5 for rom 88570008 please?
I hear it is ready now but boost control has not been tested, so I might as well make sure it is all 100%!
Cheers!
Regards
Sohail.
Cheers!
Regards
Sohail.
