PATCH: TephraMod V5
#467
FYI, for anyone trying to track what is going on with this low load knock, there was a theory posted in this thread:
https://www.evolutionm.net/forums/sh...d.php?t=341527
I'm pretty fine with believing that the car has always been doing it, you just didn't notice it before ... but update us with any new information if that theory changes
#468
#470
Tephra,
I've moved some of the local circuit track guys over to the Alt map stuff since they use 91 oct for daily and 100 at the track. So far they have all been 03-04's and I have used the 94170014 - V5.1 roms.
All using ECU-boost. Works like a charm. Makes me wish the 05+ still had the ISC button as it just works so awesome and so OEM like.
The guys are super happy about it!
Just sent you another nice donation
btw, I have fallen out of the loop a little bit about V5 for the USDM 05 evos. Is the only solution still to turn-off the immobilizer?
#471
96940011....my rom falls into that catagory of not being able to have any room right?
if there is a patch out it would be amazing
another idea i had(im sure this may have already been thought of) has anyone ever thought of removing all the anitlag tables and corresponding data? i dont see them serving any purpose being there on pretty much any USDM evo
#474
https://www.evolutionm.net/forums/sh...d.php?t=334065
#475
#476
88570008 users:
I have just emailed what I hope is the final V5 ROM to John.
Once he gives the thumbs up I will post it here.
Just a general FYI, 88570008 V5 contains a few changes over other V5's that allow John to do his Live tuning stuff. I will probably call it V5.5, when I get around to it I will do the same changes to other V5 ROMID's.
#479
Thanks JCS, the scaling for tps work! Bump into another trouble, the car jerk at 4000rpm, feels like rpm cut. When compare my old jdm boost limit vs tephra, the scaling is only set to 4000rpm. Anyone have a better scaling for boost limit? Anyone had similar problem rev above 4000rpm?
Datalog + rom + xml can be found here
