PATCH: TephraMod V5
Old Apr 29, 2008, 06:10 AM
  #481
Oracle1's Avatar
Excellent!
Dr Banks - Do the right thing!!!!
I would not make a good Dr because I'm no good with patience
SK
Originally Posted by tephra
88570008 users:
I have just emailed what I hope is the final V5 ROM to John.
Once he gives the thumbs up I will post it here.
Just a general FYI, 88570008 V5 contains a few changes over other V5's that allow John to do his Live tuning stuff. I will probably call it V5.5, when I get around to it I will do the same changes to other V5 ROMID's.
Old Apr 29, 2008, 06:11 AM
  #482
sub7's Avatar
Yes, I can rev over 4000rpm but car jerk like rpm cut... I did not boost at all... I did slow rev. You can see the rpm drop and up in datalog. I guess I'll do another log for you shortly... reving up to 5000rpm
Thanks!
Old Apr 29, 2008, 06:43 AM
  #483
tephra's Avatar
what is your TPS NTLS threshold set to?
edit just looked at your rom so 98.4
looking at your log, you need to log load/2byte load preferably
you need to fix your TPS - 5% is too low for no throttle, it should be about 13%
if you were hitting fuel cut then i suspect the IPW would drop to 0.
is your clutch switch connected?
did you do the NLTS test routine? ie speed=0, tps=20%, rev and push clutch?
Old Apr 29, 2008, 07:06 AM
  #484
sub7's Avatar
Thanks for replying, I'd disable NTLS and vallet mode, so I assume it won't affect normal cruising above 4000rpm. I did 2byte load and rpm, it's in AR and AS row. From the log, IPW drop to 1.7 (column 64).
The data was logged on 3rd gear, I'd never rest my feet on the clutch.
Old Apr 29, 2008, 07:09 AM
  #485
sub7's Avatar
Geez, I saw my NTLS is enabled. Let me disable it and do another pull... will be posting another datalog shortly.
Old Apr 29, 2008, 07:42 AM
  #486
sub7's Avatar
Here's another one. I did 3 logs... 2 x 3rd gear and 1 x 2nd gear. Datalog
Old Apr 29, 2008, 08:57 AM
  #487
jcsbanks's Avatar
Originally Posted by Oracle1
Excellent!
SK
All looks fine except I would make the init code 0001 and the alt boost and duty maps the same as standard.
Old Apr 29, 2008, 03:57 PM
  #488
tephra's Avatar
is the init code not 1? thats the original map i got from you - do the FQ's change the init code?
sub7 ill look at your log today...
Old Apr 29, 2008, 04:18 PM
  #489
sub7's Avatar
Thanks mate!
Old Apr 29, 2008, 04:31 PM
  #490
jcsbanks's Avatar
Yes the 9 FQ models come with an Ecutek remap, the one you've based on is FQ360 non-MR. Changing init to zero will just help people not to accidentally lock themselves out without realising. Lots of gotchas on these JDM/UK models, but they have all the toys (manifold temp/pres, SAS, IC spray, dual boost solenoids, single cat, single O2 sensor, on the FQ models also exhaust, IC pipes, turbo inlet pipe, panel filter, and on the 360 a sports cat and fuel pump).
Old Apr 29, 2008, 06:39 PM
  #491
tephra's Avatar
init = 1 yeah ? not zero?
88570008 is up!
Old Apr 29, 2008, 08:44 PM
  #492
tephra's Avatar
now that 88570008 is done I will be working on 88840017!
Old Apr 29, 2008, 10:49 PM
  #493
al\lupo's Avatar
Old Apr 29, 2008, 11:55 PM
  #494
mlocatel's Avatar
Great tephra
Old Apr 30, 2008, 05:48 AM
  #495
agron25's Avatar
cool
Quick Reply: PATCH: TephraMod V5
