PATCH: TephraMod V5
Old May 3, 2008, 03:08 PM
  #526
Evo8Emperor's Avatar
Nice thanks for the help just wanted to make sure obviously.
Old May 3, 2008, 03:20 PM
  #527
vroomevo's Avatar
how about 94170008 evo8 map??
Old May 3, 2008, 06:08 PM
  #528
sllt1776's Avatar
Originally Posted by Jack_of_Trades
Totally fine, also can use the 94170015 ROM as well. These are reflashed by the Mitsu dealers to fix P0300 codes usually. I have reflashed quite a few 0008 roms with the 0014 patches with great results.
Funny, I'm doing this right now too. going from 0008 to 0014. Do you think it is best to copy each table over. I checked all the tables, of course, ones I have modded are different but i noticed a few that I did not touch that were different. Is it best to stay with the settings from my 0008 or go to the 0014. The tables in question were, Open Loop Loads (all 4 RPM were different), desired idle and ISCV (temps were different, step were the same), Air temp compensation (temps were different), and boost limit RPM scale was all messed up. I figured the changes in the 0014 tables to those settings were just updates Mitsu implemented.
Old May 4, 2008, 05:42 AM
  #529
tephra's Avatar
Originally Posted by sub7
Yes, I can rev over 4000rpm but car jerk like rpm cut... I did not boost at all... I did slow rev. You can see the rpm drop and up in datalog. I guess I'll do another log for you shortly... reving up to 5000rpm
Just a quick update for everyone else.
The ROM being used was somehow corrupted/changed after downloaded.
sub7 has now redownloaded the ROM and applied his changes again...
ALL GOOD
Old May 4, 2008, 05:45 AM
  #530
sub7's Avatar
Evoryder, add this to your 94170014 XML, just above the </rom> at the end of the file.
Code:
<table name="MUTE3" address="384e6" type="1D" level="4" scaling="Hex16"/>
<table name="MUT83" address="38366" type="1D" level="4" scaling="Hex16"/>
Enter 0x8425 into MUTE3
Enter 0x8929 into MUT83 (might already be set to that value)
This is the code for evoscan to log them. Not sure what you might need to change for Mitsulogger if thats what you use.
Code:
<DataListItem DataLog="N" Color="" Display="ALT MAP Activation" LogReference="AltMapActive" RequestID="E3" Eval="x" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="1" Notes="Alt Map Activation. 0= Standard Maps 3= Alt Maps" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="ALT Map Input Voltage" LogReference="AltMapVoltage" RequestID="83" Eval="(x/256)*5" Unit="Vdc" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="15" ChartMin="0" ChartMax="15" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Sorry to dig old post, can 0x8425 and 0x8929 work with 90550001?
Old May 4, 2008, 05:46 AM
  #531
sub7's Avatar
ALL GOOD
Yeap, lesson learnt. Big thanks tephra, token sent.
Old May 4, 2008, 07:38 AM
  #532
Jack_of_Trades's Avatar
They're different huh? If memory serves me, I didn't notice any difference in those tables when I have done the swap for users in the past. I could be wrong though. Leaving them at the 0014 settings shouldn't do any harm for those particular tables. I would try the 0014 tables first and if there are inconsistencies, go back to the 0008 settings I guess.
Old May 4, 2008, 08:29 AM
  #533
sllt1776's Avatar
That's my plan. The table in question do not look like they would hurt the car, just temp and such at which idle adjust and the like. Any table that had important control was the same (except for ones I had modded in tuning of course). If i see any issues, i will report them back and update those few tables to match my 0008.
Old May 4, 2008, 05:06 PM
  #534
ant_turbo's Avatar
How do I disable valet mode??
Can I just delete that in the new patch.?
Old May 4, 2008, 05:28 PM
  #535
Just place a 0 in the mod options list instead of a 1.
Old May 4, 2008, 05:30 PM
  #536
ant_turbo's Avatar
ok thanks,, So basicly like this,, ALL I want is the NLTS..
Old May 4, 2008, 08:17 PM
  #537
tephra's Avatar
correct!
Old May 4, 2008, 08:31 PM
  #538
ant_turbo's Avatar
Ok THANKS,,,,,
I have 1 more question about the NLTS What would be good settings for my
evo_9 GT30R,,, PS DONATION COMING SOON,,,
My 2step is @6500 and my rev limt is @8000..
correct!
Old May 4, 2008, 08:41 PM
  #539
TPS=95%
RPM DROP= 800 to 1000 rpm
speed= 20km/h
Load= 50 to 100
Careful getting used to the NLTS. The clutch switch is VERY sensitive! If you accidentally rest your shoe on it while over 95% TPS, you'll think you just hit fuel or boost cut and the car starts dropping rpms instantly (cuz thats what NLTS does ). It gets me once in a while.
Old May 4, 2008, 08:45 PM
  #540
ant_turbo's Avatar
Cool I try it out!
Ok I know what is TPS is and the RPM DROP and speed!! What is the load stand for,
TANX//
Quick Reply: PATCH: TephraMod V5
