PATCH: TephraMod V5
#571
For EVO IX RS 88580014 is ok.
Only when I switch on alternate map, the fuel trims go to 100.
Seems that when I release the pedal accelerator, the AFR doesn’t follow the stock condition: is more rich then original map.
#573
I don't think the evo 7 has 2 clutch switchs on it, the only 1 there is the 1 for starting the car with, and you need a different clutch switch to use with nlts.
However I am not 100% on that, best to wait for someone else to confirm, I do know NLTS works on this rom as barryc on here has wired up the switch to his evo5 and it works on his car using this rom.
I also use this rom on my Evo 6, and I use the external switch for ALT map's and again can confirm it works from the ADC0F connection on the ecu, again barryc has wired his car up to use the autoICS switch and his map switching works 100% from that too.
Have you got the correct setting in the tephra mod options table for the Alt Maps ?
i.e 1 if your using an external swith connected to ADC0F or 2 if you want to use auto ICS.
Alt map wise, the setting are Flash ICS on alt map=1, ADC0F=2, activate time=1500 and load=100. Hold my Auto ICS for 1.5s, 2s, 3s.... the ICS won't blink. Guess I might need external wiring
#574
I agree cossie.. the wsm indicate there's only 1 clutch switch. I wish there's alternate way putting a different clutch switch, what would be my option?
He has managed to hardwire it all in, and get it working
#576
I did dave, MUTE3 with 8425 and MU83 with 8929. I'm getting 255 and 0.
<DataListItem DataLog="N" Color="" Display="ALT MAP Activation" LogReference="AltMapActive" RequestID="E3" Eval="x" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="1" Notes="Alt Map Activation. 0= Standard Maps 3= Alt Maps" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="ALT Map Input Voltage" LogReference="AltMapVoltage" RequestID="83" Eval="(x/256)*5" Unit="Vdc" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="15" ChartMin="0" ChartMax="15" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
#580
Did 30 mins drive and countless press on autoics button for 2sec, 5sec and even 10sec but the ICS ain't flashing. Autoics=2 and load=100. These is the value show for entire 30 mins
AltMapActive = 255
AltMapVoltage = 0
I think I need to test my ecu pin 35 and 44, what volt should I aim for if AutoICS is working?
AltMapActive = 255
AltMapVoltage = 0
