PATCH: TephraMod V5
#751
Dave, if you're taking requests for future versions, would you be willing to add a small amount of code to reset the fuel trims back to zero at boot?
(Can you tell I'm rescaling my injectors right now? E-85 is nice, but I didn't miss chasing my tail with fuel trim adjustments.)
#752
How do we tell if valet mode is active? I tried manual valet mode on my 88570008 and it worked fine. However, auto valet on fresh ignition didn't work consistently. There were times when upon fresh ignition, I depressed the throttle to deactivate valet mode only to find that I activated it instead after driving off. That means auto valet on fresh ignition wasn't working for that instance. So sometimes it worked and sometimes it didn't...could it be due to the turbo timer?
#754
Not so much "disable", as "give myself an easy reset button" by just turning the car on and off. It'd be nice to be able to dial in fuel trims from a known blank slate with each flash (and figured something based off of ignition would be easier). Don't the IX's reset trims with each flash?
#765
Jim, I modify the xml in a different location for version control. I was not sure if you where doing the same that is why I asked. YOu do not have to do it, but I know I have forgotten to copy over before.
SOunds like you may need to wipe everything clean and start again, just to verify.
Any other ideas? Suggestions?
