Map rescaling..
I think we do since we need a set base point for the ECU to make calcuations from that fall under, say our lowest point, 500RPM or 10 load.
Holy crap is that just like the subaru ignition correction table? Were its added that on top of base timing.
Seriously you guys didnt see the thread? Okay I will link it but only this once since I like all of you
https://www.evolutionm.net/forums/sh...d.php?t=318623
It doesnt work as fast as the Subaru version unfortunately. If it detects 1 count of knock it will default to the normal map immediately. Sometimes it works and others you cant see it in the map. I am sure there are other maps that we havent uncovered that determine all the variables, but until I really dive into disassembly (and get the time to do it proper) or someone else does we just dont know.
0 load must be there for limp (blown pipe for instance) and some other base calcs...taking it out will probably work still, but there is no point when you can alter the rest of the table as I showed...Even the VIIIs have plenty of interpolation and space to make it work.
Now that IXs have 1 ignition map, I wouldnt mind seeing it get boosted to 26x26 or something obscene. That reminds me I need to re-up on the Tephra fund.
Yeah, I want one kickass set of maps. Why should the stand-alones have all the fun huh? Tephra is working his butt of with these patches and deserves quite a pat on the back, not to mention he's still browsing the threads to help us newbies out,lol.
This rescale was from a few weeks ago to show what you can do with the stock map if you work with it a little. Obviously its for a IX and you have an VIII but again it shows what just dropping the 10 and 20 can add. In the case of the VIII you'd be to 300 with no other changes.
Here is a quick cut/paste from a data log (4th gear)
4410.15625 334.0625 32.50315 11.4513 1707.047031
4457.03125 334.6875 32.50315 11.3778 1737.710781
4476.5625 336.25 32.69662 11.3043 1747.244063
4324.21875 345.9375 32.69662 11.2749 1688.275313
RPM2Byte, Load, JDMMAP, AFR and Airflow2Byte
Here is a quick cut/paste from a data log (3th gear)
4613.28125 313.75 29.98804 11.3043 1679.626563
4691.40625 315.9375 30.18151 11.2749 1721.199531
4808.59375 314.0625 29.79457 11.3043 1755.794531
4898.4375 314.375 30.18151 11.4513 1761.98625
4980.46875 314.6875 29.98804 11.3631 1803.755781
So I found out something extremely strange yesterday. I popped off my valve cover late last night to make sure that a few things were still good under there, and pulled my plugs to read what was going on.
Two of my freaking plugs were BR8ES, and two were BPR8ES's. What the hell? I pulled out the garbage and found all of the boxes that the plugs came in, and yeah, all the boxes said BPR8ES. I think these were from the box of all new plugs a friend gave me after he sold his Evo. He must have not put them all back in the same boxes or something. I doubt NGK would have gotten that wrong. And I remembered when I gapped them I was paying more attention to my future wife Stephanie March on Law & Order more than my plugs.
No wonder the car was running wierd. Maybe tonight I will have some really good data logs to look at then, and post up.
BTW, it's a heavily modified IX turbo.
So, I rescaled the maps, and the driveability of the car was immediately improved with the resolution brought back into the low end of the car. I am still getting some knock, up to 7 counts, always in the 27-3500 range, usually from a standard start off from a green light. that part of the timing map was brought back to stock, so it looks as though I am needing to take even more timing out in those load/rpm areas. I am surprised, I have taken almost 6 degrees out of that area of the map, and the car still consistently knocks. (The counts are going down as I pull timing.) Anyhow, here is the rescaled load values I am using:
40
60
80
100
120
140
160
180
200
220
240
260
280
300
320
340
360
I was able to add a lot of timing back into the 100-200 load areas, and in some cases, almost 5-7 degrees more. The car has regained it's low end pull during spoolup.
So, tonight I am going to go out for some pulls, and get the afr right where I want it, along with boost and timing. (And others as well).
Should have some interesting data logs tomorrow, or Wed to look at.
Bryan, I am sure you might want to take a look at them, as you seemed kind of curious as to my 32.7psi on 93..
40
60
80
100
120
140
160
180
200
220
240
260
280
300
320
340
360
Oh yeah now I remember seeing that.
