Evoscan wide band reads 5.000 at idle Gauge reads normal
So here is my problem my gauge reads correct at idle 15.xxx and WOT is 11.xxx. However, when hooked up to my laptop evoscan reads it at 5.xxx. It worked just a couple of days ago when I logged and now even at WOT it reads in the 3 range. I changed to couple of different maps and it did not fix it. Also, I reinstalled Evoscan and no fix there. Car seems to be running fine so I am stumped.
Welcome to my world, just purchased 2.1 from 2.0 thinking the fix was in there. Mine has never worked. I can log in logworks and ecuedit though. But evoscan is easy and familiar. Hopefully 2.2?
This is worth a shot but have you ever unplugged the cable while the sensor was on? I did this once and it messes up the LC1 programming - you have to open LMProgrammer and select Gasoline from the drop down menu.
my lc1 worked fine with evoscan 2.1
I updated to 2.2 and it just reads 0 now
Also noticed that evoscan is very very very slow to log now too, and all the logs I did today are useless.
So I am going to remove 2.2 and reinstall 2.1
