need help: new xml files for upcoming ECUFlash release
#181
My Comp. @ work runs win.XP. My laptop runs win.Vista... Im not sure about the built in zip/unzip. I do know I was able to open/post up zip files before on both comps. now I can not! I installed the latest version of winzip on my laptop and no change... I was gonna try it on the comp @ work, but it didnt fix the issue on my laptop,so...
I just tried to open the new zip from al/lupo and still Nathan!
Drama...
Drama...
#187
Let's try a little experiment. Here are the files again (zipped on a pc with the built-in compression software), but this time posted on my web server:
http://se30.dyndns.org:8080/EVO/evo_...s_rezipped.zip
#188
#190
Hope all is well with you Naji other than the obvious winzip fiasco.
PS Thanks again Mr. Fred for this and all that you do. Me being lazy paid off I will get this new xml installed this weekend as I never did get around to installing the new idle tables separately
#191
#193
Small correction on the 96530006 file. The 96530006 file shows the following for the IPW Adder:
<table name="IPW comp starting" address="3822">
<table name="Coolant Temperature" address="69be"/>
</table>
Code in the evo7base file:
<table name="Cranking Enrichment IPW Adder (Main)" category="Fuel" type="2D" level="2" scaling="TimeInjCranking">
<table name="Coolant Temperature" type="Y Axis" elements="8" scaling="Temp"/>
</table>
<table name="Cranking Enrichment IPW Adder (Unused)" category="Fuel" type="2D" level="2" scaling="TimeInjCranking">
</table>
With the original code the IPW adder will not show in Ecuflash. If I change the ROM xml to match the base xml it shows.
Also can someone review and let me know the correct address for the IPW table. I read mattjn talk about 3732 and 3742. Just need verification so we can get it added.
</table>
</table>
</table>
#195
thanks mrfred, im confused with one thing:
C) Change the "<include>evoXbase</include>" to "<include>evoXbase_20081101</include>" ("X" should be change to 8 or 9).
i think you mean ("X" should be change to 7 or 9)
