need help: new xml files for upcoming ECUFlash release
#65
I'm going to post 88840016 and 17 soon.
An opinion: is there a way to show "Coolant temp scaling" and "IAT scaling" in a better way? In horizontal or vertical it is too long...
#69
Done my best with the attached by manually editing your 88590015. There are a lot of differences between JDM and US with maps in one that aren't in others (eg no knock filters, EGR, evap, but twin solenoids, IC, SAS), but I've tried to stick to the style where possible. I haven't had chance to look for your newest boost control stuff, even logging WGDC doesn't work so far on JDM - there are two channels and the code is rather different. I cannot test it in Ecuflash (which is 1.29a anyway) without messing up my installation even by moving and renaming files (I've tried) as I have too much stuff inheriting other stuff and I get loads of parser errors when I try. I hope my weak attempt over the last two hours helps! I cannot put much more into it as I'm packing to move house.
#70
#72
Another question for you tephra -- In going through jcsbanks IC spray stuff, I noticed that your revised IC spray section left out the following entries that were in the original IC Spray section:
Do these tables not exist in your ROM or all ROMs?
Code:
<table name="IC Relay Timer ON Mode Switch Time" category="IC Spray" type="1D" scaling="TimeSec"/> <table name="IC Relay Timer On Time" category="IC Spray" type="1D" scaling="TimeSec"/> <table name="IC Relay Timer Off Time" category="IC Spray" type="1D" scaling="TimeSec"/>
#74
The On mode switch time is confusing and not necessary, the on/off might be useful to set the effective duty cycle when the spray is active, although I don't think I changed them from stock.
