evoscan when I start logging RPM goes to +/-2500
when I start logging with evoscan the RPM goes to +/- 2500 for 1 min or so then drop back to regular idle for a couple seconds then back to 2500 rpm...
Is that normal?
Also all my logs are totally off
RPM looks like that that was a 2500-5000 rpm pull in 3rd
4000
62.5
875
4000
31.25
187.5
62.5
7750
218.75
62.5
875
218.75
etc...
TPS the same
9.01960784313725
50.1960784313725
0.392156862745098
16.078431372549
97.2549019607843
1.96078431372549
9.01960784313725
16.078431372549
and all other values are similar reading 300+ knock sometimes etc
What am I doing wrong?
Help please
Is that normal?
4000
62.5
875
4000
31.25
187.5
62.5
7750
218.75
62.5
875
218.75
etc...
TPS the same
9.01960784313725
50.1960784313725
0.392156862745098
16.078431372549
97.2549019607843
1.96078431372549
9.01960784313725
16.078431372549
Help please
1, is your laptop on battery or car power? does not using car power solve it?
2, is the white plug removed? some people have difficulties logging with this plug connected.
3, you may have to remove and reinstall evoscan on your laptop.
4, baud rate and wideband set up correctly?
these are the things I worked with when something similar happened to me.
the reinstall was the finial answer, but I think that was because the reinstall reset the baud rate for me.
Ross W
Nov 14, 2012 03:32 AM
tlclee
71
Dec 1, 2006 08:13 PM
