Tuning the Green - Initial impressions vs. Stock Turbo
Old Apr 9, 2008, 01:29 PM
recompile's Avatar
Originally Posted by slicedbreadno2
Very nice gains are both dyno pulls on a mustang dyno?
The chart is an on-road estimate dyno, not a real dyno.
I'm going back to the same Mustang I was at last week to have a good apples to apples comparison of Stock vs. Green.
For reference, I made 322whp on the Stock (340whp on this on-road dyno). A rough estimate for what I'll make now is 370whp on the actual Mustang. Not bad for pump gas and stock cams, I'd say... but we'll see.
Old Apr 9, 2008, 01:32 PM
IEXCELR8's Avatar
So you also changed all these besides the green?
344whp 388whp
Stock Turbo >>> FP Evo Green Turbo
Stock Manifold >>> Ported/Coated Stock Manifold
Stock Hotside >>> Ported/Coated 10.5 Green Hotside
Stock O2 Housing >>> Ported/Coated eBay O2 Housing
Stock WGA >>> Forge 20psi Actuator
#60 Boost Pill >>> #65 Boost Pill
Were both runs with the same boost?
Old Apr 9, 2008, 01:34 PM
recompile's Avatar
Both runs are targeting 25psi, although the stock turbo runs out of breath and tapers to 20psi.
And yes, all that other stuff was changed.
Old Apr 9, 2008, 07:30 PM
nj1266's Avatar
Originally Posted by razorlab
I would say it's more that forge actuator and him still tuning the WGDC curve. All the HD actuators I've seen need the "bathtub" wgdc curve.
It could be both.
I have seen such boost curve with the Ebay/Megan O2 and the FP actuator. The latter is on an Evo 8 with an FP green that I gave a mini-tune to. After he adjusted the actuator, the curve became better.
I guess we will not know until SC finishes his tune.
Old Apr 9, 2008, 07:32 PM
nj1266's Avatar
SC,
Did you adjust your FP wastegate to have maximum boost earlier in the rpm range rather than in the mid range?
Old Apr 9, 2008, 07:58 PM
recompile's Avatar
It's not the FP WGA, it's a Forge WGA... but I haven't had a chance to work on the tune. I'll have a little bit of time tomorrow night and I should be able to post my results.
Old Apr 9, 2008, 09:56 PM
taenaive's Avatar
no, don't change the tune! just go to the mustang dyno. I wanna see the difference between dll and mustang.
Old Apr 9, 2008, 10:17 PM
SICK9's Avatar
NICE, I just put almost the same stuff on mine a few weeks ago and came up with almost the exact same numbers..
395 whp / 363 tq..
24 psi
Time for METH now, I want 400+, hehe
Old Apr 10, 2008, 01:36 AM
spdracr's Avatar
nice numbers
Old Apr 10, 2008, 06:50 AM
xiaoni420's Avatar
Good results, but it would be nice to see the curves that the stock IX turbo would have put down with the addition of all the other mods. Regardless, curve looks great.
Old Apr 10, 2008, 10:36 AM
tkklemann's Avatar
Nice results, but a few probably ignorant questions:
No cams?
Curiosity, why are you targeting 25psi? On my ported IX turbo, I found it likes to sit right around 28psi/28.5psi, where I get the most HP w/ good timing numbers. I found running the IX to low 30psi's with mediocre timing numbers didn't really do enought to justify it.
Seems as though since the green is a more efficient turbo, you could target more like 28/29psi and give the car more power, and most likley not have to drop the timing numbers very much at all.
FWIW, I am hitting 325's with my current tune, running around 5* peak torque, spiking 28-28.5psi and holding 24.5psi to redline, with 17* up top.
Old Apr 10, 2008, 10:44 AM
recompile's Avatar
Originally Posted by tkklemann
No cams?
lol, everyone rattles me about the cams... I'm seeing what I can do on stockers for now.
Are you running 28psi on straight pump gas? I will definitely experiment with running more boost. I would imagine with that much boost & timing, you have meth or 100+ octane... I'm on straight 93 for now, and my timing map is definitely maxed out... I can't run more than 6 at peak torque and 12 at redline with a flat 25psi boost profile.
Old Apr 10, 2008, 10:55 AM
RazorLab's Avatar
Received 1,056 Likes on 764 Posts
haha, you sure your knock sensor still works?
Given I am on 91, but I can only run about 2* at peak boost (27psi), and about 11* up top (23.5psi)
Old Apr 10, 2008, 11:31 AM
TouringBubble's Avatar
Sounds like he's on Meth/water.
Old Apr 10, 2008, 06:03 PM
recompile's Avatar
Here's the WGDC I ended up with on the #65 pill and Forge WGA for 25psi target
I only did 3rd gear pulls for this, and the chart below is with no error correction.
Quick Reply: Tuning the Green - Initial impressions vs. Stock Turbo
