how-to: Log AFR from the LC-1 w/o a serial cable
Old Jan 10, 2010 | 04:14 PM
  #301
mrfred's Avatar
Originally Posted by Drill_Sergeant
mrfred, or anyone who can help, how should i adjust my formula to make it read more closely to the gauge itself. my AFR's are about +0.1 to +0.2 compared the gauge.
my values im using are 19.98-10.0, so the current formula is 0.03913*x+10
This is for the AEM?
Old Jan 10, 2010 | 04:30 PM
  #302
Drill_Sergeant's Avatar
Veteran: Army
oh yes im sorry. this is for the AEM UEGO
Old Jan 10, 2010 | 04:37 PM
  #303
Danieln's Avatar
Danieln, the "x" is strictly for logging with serial cable under the "external wideband" option.
the placement for the formula you input is for the "wideband AFR" option shown here:
I just realize that after I read more of your posts.
Thanks a lot
Old Jan 10, 2010 | 06:07 PM
  #304
mrfred's Avatar
You're formula is correct for an ideal analog input, but often there are ground offsets in the analog input signal. When I checked my rear O2 analog input, there was a consistent offset of around 3/255 which is approximately 0.1 AFR for my LC-1 calibration. See this post:
https://www.evolutionm.net/forums/ec...ml#post5537603
If the AFR read via the analog input is low, then add to the offset, e.g., use:
0.03913*x+10.2
If its reading high, then subtract the amount its reading high, e.g., use:
0.03913*x+9.8
Old Jan 10, 2010 | 06:10 PM
  #305
Veteran: Army
^^^^^^^^ thanks
Old Jan 10, 2010 | 06:18 PM
  #306
mrfred's Avatar
^^^^^^^^ thanks
NP. That was an easy question. :-)
Old Jan 10, 2010 | 08:39 PM
  #307
Veteran: Army
i'll be testing it out tomorrow
Old Jan 11, 2010 | 07:44 PM
  #308
Veteran: Army
mrfred what should i do if its low by 0.05?
that's about as close as i cant get to perfect?
Old Jan 11, 2010 | 07:53 PM
  #309
mrfred's Avatar
Within 0.05 is pretty good, but if you're sure its consistently low by 0.05, then increase the offset by 0.05.
Old Jan 11, 2010 | 08:31 PM
  #310
Veteran: Army
actually looking at it sidebyside on excel, it shows its pretty dead on during idle, but when WOT it's -0.2 to -0.3
Old Jan 11, 2010 | 08:51 PM
  #311
mrfred's Avatar
Assuming you did a good job grounding the AEM controller, then it sounds to me like either the calibration that AEM provides for the analog out is incorrect, or the gauge is reading incorrectly. Probably safe to assume the gauge is correct and the analog out cal is wrong.
Assuming that WOT is richer than idle, then to get the analog out to match the gauge, you need to decrease the slope (multiplication factor) slightly increase the offset a bit. If you tell me your AFRs at idle and at WOT for the guage and the analog out, I can work out the correct formula for you.
Old Jan 11, 2010 | 09:13 PM
  #312
Veteran: Army
how about i email you the log?
PM me for my email?
Old Jan 11, 2010 | 09:34 PM
  #313
mrfred's Avatar
PM me for my email?
Not sure I have time to analyze a log. Try 0.03693*x + 10. With that slope, AFRs should be high/low by the same amount at idle and WOT. Adjust the offset to get rid of any difference.
Old Jan 12, 2010 | 07:38 PM
  #314
Veteran: Army
here is a small clip from the log...
also i posted a question in your logging boost thread about a P0108 code upon start ups.
Old Jan 14, 2010 | 01:33 PM
  #315
hediki12's Avatar
i think i may have figured out why the analog is off.. i have 2 harneses for my car so i have tons of ecu pins and looking for a pin i noticed that the wire going to the rear o2 (from the spare harness) has a plastic wrap over it. so i pealed back a little and found that the o2 wire is surrounded by insulating wire connected to a ground wire so i cut the whole thing and used it. im wondering if the insulated wire thats grounded is used to stop interference /static? like how a room with alot of copper piping will stop cell phone signals. i havent been able to test this as that i just installed it (yay) and the o2 sensor i buy is dead (fml) . so let me know your input on this.
