Boost solonoid harness able to be used for input?
Since I dont use ECU based boost control and with a lot of people wanting to change to a type of speed density I was wondering if the solonoid harness could be used for an input of an AIT sensor. With my no knowledge of disassembly hopefully someone could have some insight on this or if it could actually be done.
The only reason why Im asking this is I just got done reading the thread which lets you use your wideband voltage in the rear 02 sensor so this should be sort of the same thing, right?
There are signal inputs and signal outputs on the ECU. We are using a signal input to read the wideband. The BCS is controlled by a signal output on the ECU. Signal outputs cannot be configured to act as inputs. Another input needs to be freed up. I am working that right now. My GM air temp sensor and pigtail arrived a few days ago. Need to start working on freeing up another ADC input.
Yeah, my intent is to use the ADC input for the fuel temperature sensor. It has a scaling routine associated with it already, so it would be a piece of cake to wire in the GM IAT sensor signal into that pin and then input the GM IAT sensor scaling into the scaling table. What will be more of a challenge is creating a reasonable simulation of the fuel temperature. I really should start logging it for a few weeks so I can see what it does.
razorlab. That's definitely the intent. I want to see what's happening across the IC. What I'd really like to do is find a way to use another ADC input to log temperature after the turbo and before the IC. I could do it with ADC_0F, but I want that one for flex fuel and map switching control. Give it some time, and I'll figure it out.
05-EVO-GSR
Feb 23, 2017 11:57 AM
TurboRSX04
Dec 11, 2008 06:51 PM
PaganImmolator
15
Apr 15, 2006 02:15 PM
