Logworks
Old Apr 21, 2008 | 05:26 PM
xpro's Avatar
Logworks
Is there any info on how to log with logworks?I have seen few members here loging most of the stuff available in evoscan(knocksum,coolant temp, etc etc)
Well,when im logging with logworks im only able to log afr,revs and TPS and intake temp when using open port feature in logworks.Is there any more info available for logworks please? And do you find logworks to better for logging afrs then Evoscan?
regards
Old Apr 21, 2008 | 06:37 PM
Asmodeus6's Avatar
I use logworks for everything. But I do not log that which I don't need to tune...
I log 2 byte load / 2 byte airflow / JDM Map sensor / RPM / A/F / Knock / Timing / IPW / and vehicle speed. Thats about it.
I flip flop between TPS / Speed so I can use the auto trigger function for logs. Then it becomes mindlessly simple.
evoscan will not work for me. It either doesn't stay connected - or just gimps. Logworks - works. 100% of the time. Without the 2 byte load portion tho - logworks is almost pointless as it clips load at 180. Not great if you spend the majority of your time at 260-300 load at WOT. 2 byte is just valuable in itself. Even compared to load calc on evoscan.
Old Apr 21, 2008 | 07:04 PM
l2r99gst's Avatar
LogWorks has a file called protocols.xml. That is the file that holds all of the requests and settings for what you want to log. You have to edit and add to that file in the same way that you would edit or add to the data.xml in EvoScan.
Eric
Old May 7, 2008 | 09:27 PM
jimib's Avatar
Yeah I have never figured out how to use logworks to log anything in the ecu. I have tried a few times while im out and gettinf frustrated with evoscan, then I give up. Ill search now on here and there forums, but if anyone is feeling generous how do you even get started logging with logworks?
Old May 7, 2008 | 10:49 PM
Asmodeus6's Avatar
Uhhh... you plug in the cable...
Double click openport 1.3...
Hit connect... pick your parameters...
Double click logworks...
Bango. Loggingness...
Old May 8, 2008 | 01:52 PM
jimib's Avatar
Yeah thats what I thought to and it doesnt work. It never connects. Ill have to actually look at it for more than a couple minutes.
Old May 8, 2008 | 01:56 PM
l2r99gst's Avatar
Do you have an Innovate MTS device? You need to connect to an Innovate device, such as the LC-1 via the serial cable before you can use LogWorks to log.
Eric
Old May 8, 2008 | 03:36 PM
jimib's Avatar
Yup
Old May 8, 2008 | 04:39 PM
jid2's Avatar
I'm on the Logworks band wagon as well and really like it.
JorgeYaHeard
Aug 6, 2011 01:02 PM
AlwaysinBoost
Sep 6, 2010 07:29 PM
lapulapu
Sep 21, 2008 05:20 PM
EVOLex
Jul 3, 2008 10:31 PM
nj1266
Jul 7, 2007 09:39 PM
Quick Reply: Logworks
